Old 12-15-2017, 12:56 PM   #1
Anti-freeze Frozen
I stopped my to check on my motorhome yesterday and noticed that the RV anti-freeze in the toilet bowls was frozen. Low temperatures have been in the low teens recently here in the Detroit area. I am wondering why this would happen and how much trouble I am going to find when I dewinterize.
mdebs is offline   Reply With Quote
Old 12-15-2017, 12:58 PM   #2
Scoundrel
HangDiver's Avatar
Is it truly frozen hard or thick like slush? Thick like slush is normal.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 12-15-2017, 01:01 PM   #3
OYO
OYO's Avatar
Correct.
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Craig
OYO is online now   Reply With Quote
Old 12-15-2017, 01:02 PM   #4
First... is it pure R/V antifreeze or is it possibly diluted with water from not first blowing out the lines?
Second... while R/V antifreeze will get slushy and possibly even freeze at below zero temperatures, (most are good for -25F to -50F, some even more), but UNLIKE water, it will not expand when frozen.
If your is diluted, all bets are off.
Days Camped: '16=46 '17=30 '18=51 '19=32
Old 12-15-2017, 01:12 PM   #5
It is frozen, not just slush. Although, I did not blow the lines out first I used quite a bit of antifreeze to run through the lines.
Old 12-15-2017, 01:14 PM   #6
So if the anti-freeze doesn't expand, does that mean it should not damage the lines?
Old 12-15-2017, 01:16 PM   #7
What brand?
R/V antifreeze for sure?
Do you have any left?
If it is freezing SOLID at temperatures 'in the teens', something is wrong with it or it is diluted.
Old 12-15-2017, 01:21 PM   #8
R/V antifreeze does not expand when frozen.
Water is the only common liquid that expands when frozen.
Old 12-15-2017, 01:26 PM   #9
I believe it was Winter Tech RV Anti-freeze. I don't have any left. Are you supposed to blow out the lines and then run anti-freeze through them. From every thing I read, it was one or the other.
Old 12-15-2017, 01:56 PM   #10
jeff64's Avatar
At least open up the low point drains, open all faucets including outside shower, pull the anode on the WH and step on the toilet pedal until its done running out. Isolate( turn the valves) the WH from the rest, even if you don't blow out with air. The RV antifreeze is close to 50% water to start out with. A few ounces of water left in the corners of the system won't matter mixed in 2+ gal. of AF
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
