01-06-2018, 10:20 PM
Anti freeze frozen
Chech the vibe this afternoon and I find that the anti freeze almost frozen in toilet. Am I going to have problems?
Oh I'm in bama. Been low twenties high teens all week.
01-06-2018, 10:38 PM
Happy Camper
Almost frozen is much better than frozen solid.
It takes the frozen "solid" effect to bust water lines, etc...
Turn on minimum heat in the camper, if available, to avoid that problem.
The heater will run off LP gas and battery power for as long as it last.
If hooked up to power, you are OK for the duration.
Cold here in Selma & Valley Grande, AL. too.
01-06-2018, 10:43 PM
Assuming you didn't dilute the AF in the toilet, it doesn't freeze solid. Touch it with something. You'll probably find it's really a "slush." Won't hurt anything.
2011 Traverse LT, 3.6L, FWD
01-06-2018, 10:44 PM
Like windshield washer fluid....
It says it "protects" to -40, not that it won't freeze. The water freezes, and expands. The methanol freezes, and contracts. The net result is the volume doesn't increase, thus nothing bursts. Or at least, that's how the blue stuff works. I'm pretty certain the rv / red stuff is identical.
01-06-2018, 10:55 PM
I’m in Canada where it get to and stays at -10 to -45 below zero Celsius for 8 months of the year. The RV “antifreeze” will slush and sometimes freeze slightly but it does not expand which is what bursts pipes. You should be fine but if you are worried, throw some heat in it like others have said until it warms up a little
01-06-2018, 10:56 PM
Thats how the RV antifreeze is designed...it turns to slush at colder temps but will not freeze and expand till -50...but if we get to -50...we have much bigger problems!!!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
01-06-2018, 11:13 PM
Yep, that's why you use RV antifreeze. Doesn't expand.
01-06-2018, 11:23 PM
Noticed my anti freeze in toilet is frozen the other day. As long as it doesn't expand it should be fine but it still gets the pucker factor going a bit.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights / 2018 = 7 nights
01-06-2018, 11:24 PM
Scoundrel
X3 You're fine.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
01-06-2018, 11:38 PM
Thanks all. new to travel trailers. 1st the AF wasn't diluted.
Just wasn't expecting to see ice there.
