Old 03-12-2019, 08:52 PM   #1
Anti-Siphon Vacuum Breaker
Is it possible for the Antisiphon Vacuum Breaker to fail in such a way to allow black tank odor into my RV.
I just returned from a 5+ week trip where I was at a park with no sewer hookup thus I had my tanks dumped once a week via a honey wagon. I have not used the black tank flush at all. When I brought my RV home after a few days in the warm Florida sun I had a very strong sewer odor, stronger than I have ever had before. It was coming from under the bathroom sink.
I suspected the air admittance valve but the spare I had was the wrong thread to replace it. So to see if I could isolate the odor I placed a ziplock bag over it and sealed it tight with a large rubber band. No luck, still odor from under sink.
I then noticed the anti-siphon vacuum breaker. I tapped on it a bit and then decided to run some water thru it. The valve did not leak but the odor went away.
I donít know how these things work but can they fail in a manner to allow sewer gas to escape under the sink but not leak when being used?
2016 Siverback 33IK
Old 03-12-2019, 09:14 PM   #2
bubbles's Avatar
Well, here's the way it is supposed to be installed:
Name:	black tank cleanout1.jpg
Old 03-12-2019, 09:33 PM   #3
Thanks, it is installed correctly. My question is can it fail in a manner to allow sewer gas to escape into RV ..
2016 Siverback 33IK
Old 03-12-2019, 09:42 PM   #4
Usually Confused Member
emm-dee's Avatar
If it failed any odor that went through it should exhaust through the port where one would hook a hose to do the flush. If you camped for five weeks and didn’t use the tank flush I believe you have a pretty nasty black tank by now. The smells will go up the vent pipe and disburse in many directions.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 03-12-2019, 10:02 PM   #5
Originally Posted by emm-dee View Post
If it failed any odor that went through it should exhaust through the port where one would hook a hose to do the flush. If you camped for five weeks and didnít use the tank flush I believe you have a pretty nasty black tank by now. The smells will go up the vent pipe and disburse in many directions.
Under the sink?
I still have not flushed but just ran water thru flush system and odor went away..
2016 Siverback 33IK
Old 03-13-2019, 09:06 AM   #6
bubbles's Avatar
The way it works is: A disk seals off the input side when water pressure is removed and opens to the main valve cavity when pressure is applied. The output side has a spring loaded check (ball) valve that opens when the cavity has pressure and closes when pressure is removed. The valve cavity is open to ambient to break vacuum for the disk to open (sealing off the opening to ambient) and also to allow the disk to close off the input side as the water in the cavity drains out of the input port and associated tubing. Can the check valve hang open and the use of the bathroom exhaust fan draw black tank odors? I suppose anything is possible. I have not had any sewer odor come from my vacuum breaker/check valve.
Old 03-13-2019, 09:29 AM   #7
bubbles described how the valve works perfectly.
Could it leak gases?... sure but pretty uncommon.
BUT, you proved it can. By running water through it and thus eliminating the odor, I'd say you found your culprit.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 03-16-2019, 01:25 PM   #8
Witch Doctor's Avatar
If it is leaking, why wouldn't the water being leaking to, I'm confused, which is easy to do, it is a closed valve, there is no outlet like for a hose bib. So how can you get smell without seeing water?
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-16-2019, 02:22 PM   #9
Most holding tank chemicals have a line in their instructions suggesting that MORE of their chemical be added as a filled tank "ages" or if weather is particularly hot. I't could be possible for the anti-siphon device on your flush hookup to bleed odor and it doesn't take much to raise a big stink.
Check you tank chemical and see what they instruct. Because it's possible for a treated tank to still contribute odor from the actual chemical itself, pick an aroma you can tolerate and try to dump/flush your tank more often.
BTW, don't overlook the gray tank. They can sometimes be just as foul as a black tank. If it's been warm or you've been on the road it's possible that there isn't enough water in the sink P-trap to block odors. It's a good idea to use some chemical in the gray tank, especially one that helps keep grease and soap buildup under control. Also minimize food scraps that go down the kitchen sink with a fine strainer available from Walmart, HD, Lowes, actually just about anywhere that sells housewares. The food scraps can "compost" and if you've ever turned over a compost pile it smells just as bad as a pile of manure until it's fully composted.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-23-2019, 02:40 PM   #10
Plano, TX
Ale_Brewer's Avatar
My bet is the odor is coming from your gray tank and the p-trap for the bathroom sink went dry.
Curtis & Melissa
2016 Solaire 247RKES GT3
2013 F-150 EcoBoost
Ale_Brewer is offline   Reply With Quote
breaker
