Old 06-04-2013, 07:57 AM   #1
smallstonefan's Avatar
Any trick for removing the water heater heating element?
Hi all,
I bought the special wrench to remove the electric water heating element, but on my camper the gas system is in the way; I cannot get the wrench onto the electric element.
any ideas?
smallstonefan is offline   Reply With Quote
Old 06-04-2013, 08:08 AM   #2
Fulltime family RVer
Grunting and swearing mostly...
Any chance that you have a picture of your setup that we might be able to throw out ideas?
Old 06-04-2013, 08:15 AM   #3
wmtire's Avatar
Originally Posted by smallstonefan View Post
Hi all,
any ideas?
If it's a Suburban, you just remove the burner tube. Here is a video showing how.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-04-2013, 04:32 PM   #4
That video is EXACTLY what I needed - thanks much!
Old 06-04-2013, 04:57 PM   #5
Didn't see him use any Teflon tape on the element or the anode and I would have pressurized the system before putting the cover on to check for leaks. If no leaks, then reinstall the cover and the gas tube. JMO.
Old 06-04-2013, 06:19 PM   #6
Hutch333id's Avatar
I'm having exactly the same problem with mine. I moved everything in order to gain access to this sucker but I cannot budge the heating element that is well and truly stuck in the water tank. I'm now booked into the dealership for them to have a go.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 06-04-2013, 06:23 PM   #7
BigTJohn's Avatar
Remember to RELEASE THE PRESSURE from the heater. I did NOT one time and blew the anode 23'. Luckily the 2 next door storage units were empty and no damage done. Would have been a big dent in the MH usually next to me. Whew!
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 06-04-2013, 06:46 PM   #8
Pawpod's Avatar
I found my next door. Also got a shower of water and anode rod crumbs. DW had a good laugh. Yes depresurize first
Pawpod is offline   Reply With Quote
Old 06-04-2013, 07:05 PM   #9
B47
X2 on your comments. In addition, why does he call the flue assembly "this piece" instead of what it is - a flue? Some people watching this video may hear the word "flue" used later someplace and wonder what a "flue" is.
Also - someone else commented correctly once that this is not a "hot water heater", but rather a water heater that heats cold water to make it hot.
Old 06-04-2013, 08:36 PM   #10
Hutch333id's Avatar
Well, I've just had a second go at trying to get the element out of my hot water tank without success. I cannot budge the manufacturer installed element. I'm using the correct tools, depressurized and drained the tank, everything. All I succeeded in doing was identifying how I bruised and scrapped my arm the first time I was trying this last weekend.
Richard & Diane
