12-23-2019, 01:26 PM
Anyone use a macerator pump at home and discharge into a toilet?
If one needs to empty the holding tanks at home and doesn't have an accessible clean-out the only viable option would seem to be the toilet.
Does anyone use theirs for the final destination from their holding tank contents, using a macerator pump.
In my mind as long as height difference is within pump's capabilities, toilet isn't too far away for size of hose, the only remaining problem would be how to keep the hose from "flopping" out of the toilet as the poo flows.
Obviously having a helper would be the best option but if you don't have one (either because you live alone or can't find a willing volunteer) what other methods work?
12-23-2019, 01:42 PM
I used my wife at the toilet to hold the hose. I have to tell you the smell isn't pleasant at all. We no longer use the toilet to empty the black water tank. I make sure it's emptied before we come home. I don't think you'll have a helper for too long doing the toilet thing. My macerator pump has good pressure when pumping and you'd have to be very careful at the toilet or else the bad stuff will be all over the good stuff.
12-23-2019, 01:44 PM
I'm looking at having an access port added to my septic tank.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
12-23-2019, 01:55 PM
We are going to get a macerator pump too. However, we are lucky and have a cleanout right next to the trailer. I wouldn't put it through a toilet myself, especially without a helper. If that hose ever jumps out of the toilet...
12-23-2019, 02:04 PM
Are you saying it might be a real case of the crap hitting the fan?
12-23-2019, 02:20 PM
Always Learning
I've dumped into a port-o-pot. I turned on the pump and raced to the other end to ensure it wasn't going to jump out of the hole. Had to have been hilarious to see. Especially once the retching started from the stench.
Haven't done a home toilet, but given the lack of helper- I would probably put the hose end in and would hold it in place with something heavy on the seat. I'd still worry about shooting it out of the space between the seat and the toilet bowl.
You're a smart guy, I'd bet you could fashion up a remote trigger that's the same length as your hose (if it's wired) or wireless that works from the same distance.
12-23-2019, 02:34 PM
I'm thinking that just parking my TT close to the sewer manhole in the street is looking pretty good. A garden hose end will just fit into the lift hole.
12-23-2019, 02:38 PM
Always Learning
I'm going to act like I didn't read that!
12-23-2019, 02:55 PM
I should be good unless I make a mistake and hit a power or phone vault.
Here they are clearly marked. Maybe they've had mishaps before.
BTW, the one near my house that's looking good is where the lift pumps empty from four houses below me on the hill. Wouldn't even notice what I might put in.
12-23-2019, 02:56 PM
Do you have a septic system cleanout you can dump into that? Mine is a PVC pipe with removable cap that sticks out of the ground between the house and the septic tank. The pic isn't of mine but looks similar.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
12-23-2019, 03:24 PM
I do not. What I would like is a pipe like yours but would probably have to drill through the access cover and install the cleanout myself.
That pic was just a quick find and post, I don't want that big of an access in my front yard.
2014 Grey Wolf 21RR
12-23-2019, 06:33 PM
Find the pipe going to septic and install a Y or sanitary tee
12-23-2019, 06:54 PM
X2 Much better than messing with any pump. When we built our house 4 years ago I had a "clean out" installed near the driveway in case we ever needed to dump at home. The only time we ever used was when we stayed in our TT in the driveway for two weeks while the house was finished. Remember if you are on a municipal system and someone asks, it is a clean out. Many municipal systems do not allow a RV dump.
12-23-2019, 07:13 PM
I am very surprised you don't have that. I have had 2 homes built in the last 35 years that do.
So how do you access your septic tank to get it pumped? You have a lid of some kind? or do you dig down to a concrete lid?
12-23-2019, 07:40 PM
The last two houses I had before I moved into an area served by sewer had covered tanks. The guy who pumped them out would just probe with a steel rod until he found the tank then poled around withing the area of the tank top until he found the concrete plug. A few shovel fulls of dirt (was only a foot or so below surface (max) and access was gained.
12-24-2019, 07:16 AM
Yep, dig it up to access the concrete lid.
2014 Grey Wolf 21RR
12-24-2019, 10:17 AM
Cousin "EDDIE" maybe!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
12-24-2019, 10:33 AM
The sanitary sewer cleanout in the front yard is preferred but not even the city had a record nor could they find mine.
No way my wife would touch let alone hold the hose. I bungie the waste hose to the toilet seat bolts. Doesn't move. Put the hose tip under the toilet liquid level and pump clean water thru the system first to make sure everything is connected properly. Waste drains quickly and since I don't poison my tanks with anything blue the smell is not overpowering. A couple flushes mid stream help.
Been doing it this way for 10 years if there's a line at the dump station exiting a state park where the oblividiots spend an hour backflushing, etc.
Storm sewer in the street is an inappropriate place to dump sewage.
-- Chuck
12-24-2019, 11:37 AM
-- Chuck
But what about the sanitary sewer? In reality the only difference is whether or not it goes through the side sewer line first or just directly into the main sewer. Ends up in the same place.
12-24-2019, 11:43 AM
If I used a metal tipped hose, I would tape over the threads. Plastic, use as is. WEAR LATEX GLOVES!
Just carefully push the hose into the toilet slowly and feed it up and through the S turn so that about a foot of hose is being fed down past the S turn. Maceate away. Look Ma, no hands!
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
