04-11-2016, 06:14 AM
Are all anodes created equal?
Looks like I need to change the anode in my tank and am wondering if they are all universal or are they tank specific ? Just realized the typo in my title, lol , sorry folks.
Here is a pic of my tank
04-11-2016, 06:36 AM
Need a Pic of your A-Rod,remove and replace with same length! Youroo!!
04-11-2016, 06:38 AM
04-11-2016, 06:52 AM
Hey we have been all around this issue on another Post of yours! This is the Same W/H just in another "Coat"! Youroo!!
04-11-2016, 06:53 AM
Well my other issue is can't get my burner started , this one is specifically for anode replacement. I'm trying to find the correct anode for my unit.
04-11-2016, 11:23 AM
Canadian Member
This is what you need.
Amazon.com: Suburban 232767 Water Heater Anode Rod: Automotive
There are a few aftermarket brands as well. Camco sells an aluminum version. I think the magnesium anode rod is better.
04-11-2016, 11:32 AM
Excellent! I will order now , thanks.
While you have the anode out you need to flush the crud that is in the bottom of the tank or else it will plug your faucets and toilet.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
04-11-2016, 11:34 AM
Too old to be too smart
^^That's the answer.^^
All of the previous rod has turned to little white chunks, and you'll want to flush those out before installing the new rod.
Use Teflon tape, too.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
04-11-2016, 11:37 AM
Georgia Rally Coordinator
You can actually go to about any camper place and pick up your new anode replacement. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
04-11-2016, 11:39 AM
I called the local camper and they want 13$ more than amazon, I can buy a couple of bags of charcoal with that 13$, lol but thanks for the tip bud.
04-11-2016, 12:06 PM
Canadian Member
Pop
Yup. And for that, there's this.
RV Water Heater Tank Flush Tool
04-11-2016, 12:11 PM
I recommend you buy two, Shipping will be a few bucks more at most and you will have one the next time you pull it out and decide it needs to be replaced. Be sure to use 1-2 turns of teflon tape when installing new one.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-11-2016, 12:21 PM
No problem just thought the shipping would make it cost about what you could by locally. Later RJD
Days camped 2019 62
04-11-2016, 01:27 PM
I personally don't mind paying the extra to keep a local business open. Amazon has killed the small business.
Think about when your on the road and something breaks, Amazon is not going to be there to help. The local guy/gal will be. I'll pat extra to support the local shop.
Don't get me wrong. I'm not anti-Amazon, there are things that are not local and worth the drive.
04-11-2016, 06:29 PM
Anode installation
Like said above you need to put a couple of turns of teflon thread tape on the threads of the new rod. It is used as more of a "lubricant" for the threads than as a sealant. Also, take a toothbrush size wire brush and clean the tank threads out well. Then flush the tank out to get rid of the anode crud and particles from the threads you cleaned up. When you go to install and tighten the anode use a 1 and 1/16" socket, appropriate extension and ratchet wrench. Take a small amount of paper, like a newspaper ad, and pack it into the socket so the anode does not go all the way into the socket, that lets you better control the rod as you install and tighten.
Now, you DO NOT want to "gronk" (over tighten) the rod. You want it good and snug, but not so tight you cannot remove it the next time and you start cussing the gorilla who last installed it. I resemble that last bit...
I got the 1 and 1/16" 1/2" drive socket socket at Northern Tool.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
04-11-2016, 06:34 PM
How are deposits in the water heater going to make their way to the toilet? It can't happen.
Bruce
04-11-2016, 06:36 PM
Pop
The white chunks in the bottom of the water heater are hard water deposits, not pieces of depleted anode rod.
Bruce
04-11-2016, 06:46 PM
I called Suburban and they recommended the magnesium anode that can be harder to find than aluminum. Used the rinse tool and hose to rinse out tank in spring with lots of water before putting new anode and sanitize system. Soon....great springer!
04-11-2016, 07:02 PM
Suggestion. Save the old anode rod, cut off the rod portion, and then save the plug for when you winterize the unit. When you winterize, change out the rod for the plug when you drain the WH. This will preserve the good rod and keep out all the junk that collects in the tank and clogs your water lines and faucets. It's a few extra step but saves you from bigger headaches in the spring.
