Old 06-02-2016, 11:13 PM   #1
Question Attaching water regulator & filter
Does it matter what end to attach the water pressure regulator and the water filter to? Should you keep them closer to the faucet to keep the weight off the connection to your trailer?
myezlife is offline   Reply With Quote
Old 06-02-2016, 11:25 PM   #2
Rupkin2's Avatar
Pretty much what I do and for the same reason.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 06-03-2016, 10:11 AM   #3
Fulltime family RVer
I do them at the trailer because I have a water bay inside of a hatch. This means that I can always leave them connected and only have to hook up hoses. It does mean that my hoses aren't protected.
If everything would be outside, I'd do it at the campground spigot solely to protect my hoses.
Old 06-03-2016, 01:03 PM   #4
Out of the 175 campgrounds we have been in 3 have warned of high water pressure. The last one took out my hose. I always connect a 25 hose to the spigot, then the reducer and filter and another 25 foot hose to the trailer. My reducer was pretty expensive (way more than a hose) so I can put it under the trailer out of the weather with my set up.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-03-2016, 09:00 PM   #5
We use a 25' from the connection to a whole house filter(Home Depot 35$) Then a 10 ' to a 90 connector to my water connection. I use a adj regulator right at the faucet before the hose.
Repl filters are very inexpensive and easy to replace. Made a holder for the filter unit out of pvc.
2012 F250 6.2 gasser 373 rear
2013 Rockwood 2104S Mini Lite
Ole Buzzard is offline   Reply With Quote
Old 06-03-2016, 09:21 PM   #6
If the CG spigot is high enough off the ground, I put the water regulator, then the filter, then the hose at the spigot. Want to keep the regulator and filter off the ground. If it's not high enough, I have a 90 degree fitting from the TT, with the filter next (upstream), then the regulator, then the hose. So the filter/regulator hang from the 90 degree fitting at the TT.
2011 Traverse LT, 3.6L, FWD
Old 06-04-2016, 12:37 PM   #7
Left Coast
On this Rockwood, the city water hook-up is on back of trailer above the bumper.....so I go regulator at faucet, hose to home style filter that sits on bumper, then use a quick coupler into trailer.....easy peasy..
Old 06-04-2016, 06:20 PM   #8
bob213's Avatar
If you put your regulator at the hose bib it will protect your hose as well. Hose bib, regulator, filter, trailer is my hook up.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ė Ayn Rand
bob213 is offline   Reply With Quote
Old 06-05-2016, 10:53 AM   #9
AKA: 'tiredTeacher
awellis3's Avatar
Me, too, 'cepting I put a Y-valve on first so I can hook up my flush hose (w/ full hook ups) and have access to water for other uses.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
water
