Old 06-12-2016, 03:48 PM   #1
Atwood Water Heater issue
Finally got around to dewinterizing the trailer. Got water heater fired up. Had long orange flames and fire up around the chamber till the vent end. A lot of black smoke . Finally got it to a nice blue flame and no fire way up in the chamber. Now it heats on propane but it won`t shut off . heats until water leaks out the pressure relief . Check circuit board connections . Any ideas ? Maybe the thermostat messes up? Only have camped 8 nites in the 2014 trailer .
Big Red and 30WR is offline   Reply With Quote
Old 06-13-2016, 11:59 AM   #2
Head Rambler
Is it also an electric? If so, when you heat on electric does it operate correctly?
Have you checked the actual temp of the water to see just how hot it is?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-13-2016, 04:16 PM   #3
I didn`t try electric but the water was up near 200 .
Old 06-13-2016, 04:19 PM   #4
don`t know why this thread got moved, Did I say something wrong?
Old 06-13-2016, 04:24 PM   #5
Ford Idaho's Avatar
No your fine, you will likely get more specific answers this way.
Old 06-14-2016, 09:31 AM   #6
Head Rambler
It sounds like the thermostat is not opening when it reaches temp. There is a high limit cutout that should shut it down, but it's set at 190F, and the T&P valve relieves about there too (210).
It could also be that the gas valve isn't closing on being de-energized, but you say it starts normally, it just doesn't shut off.
Gotta go campin!
Old 06-14-2016, 09:59 AM   #7
wmtire's Avatar
Nothing wrong was done on your part. The site team moves threads to more appropriate forums, not only to help the OP...but also for members who later may be searching for similar problems.
I am going to tweak this one a little more, as it should really be in the plumbing/water systems/fixtures subforum, where you may get more specific help.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 06-14-2016, 05:11 PM   #8
I`ll post what was wrong when I get a chance to work some more on it. This may help others if there have the same problem. The thermostat doesn`t look that hard to replace (thanks to youtube)
Old 06-14-2016, 05:16 PM   #9
However I did notice when the propane burner was on , I Had a red light flickering on the circuit board and sometimes 2 red lights flickering.
Old 06-20-2016, 03:54 PM   #10
Had the dealer fix it. They said I had spiders in the burner tube and they adjusted it. I`m assuming the draft control . Hope this may help others farther down the road .
heater, water, water heater
