Old 04-13-2019, 10:52 PM   #1
Adrian Gordon's Avatar
Atwood water heater not igniting
We have an Atwood water heater. Model G6A-8E. It is a six gallon, gas only, electronic ignition heater. It is original to our 2018 Coachmen Leprechaun 210RS and is a little over a year old.
When we turn the water heater on at the control panel inside the RV the igniter clicks, but I do not see any spark anywhere. The DSI light comes on, flickers a little and goes out. There is gas at the heater because we can smell it when we initially turn the switch on but the heater does not light off. It attempts to start a total of three times and then locks out until the switch on the control panel is reset. There is water in the tank and the valves are all set to the proper dewinterized positions. The system has worked within the past two days.
The 2 amp fuse on the tank circuit board is good. The 15 amp fuse in the fuse box labeled "Heat Tank" is also good, although I have no idea on earth what this fuse does given there is no electric heating capability with this unit.
Any ideas on where my problem may be?
2018 Coachmen Leprachaun 210RS with DW, a German Shepherd and the cat.
Adrian Gordon is offline   Reply With Quote
Old 04-13-2019, 11:44 PM   #2
RandK-M's Avatar
I had a similar problem right at one year old, I could hear the click, click, click of the igniter, but no spark and then the red light would come on after three attempts. All I did to fix it was remove the igniter with the one little screw that holds it on and clean the probe and the area where it sparks to with a little wire brush, reinstall the igniter and it fired right up. It's been fine for two more seasons so far without failing....*Knock on Wood*
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is offline   Reply With Quote
Old 04-14-2019, 08:50 AM   #3
Witch Doctor's Avatar
Try what Randk says first. Those atwoods are famous for bad boards, had the same problem mine was the garbage board. It wouldn't allow gas to pass. If it is the board, when you install the new one put a spacer in to keep it off the face, the solder joints break from that little heat on the face it seems, been a year now with mine no problems, but I also carry a spare board, they are that bad.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-14-2019, 10:51 AM   #4
sounds like air in system did you try lighting stove all burners? and start refrigerator on propane? then try your hot water tank.
cfo111 is offline   Reply With Quote
Old 04-14-2019, 11:07 AM   #5
Did you have water in the tank when you tried to light it? If so, the other thing to look at is next to the 2 amp fuse. It is called the thermal cut off. Easy, cheap replacement.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
TV - 2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Drinks of choice: woodford reserve, knob creek & any great bourbon-just about any of San Diego’s craft beer and Pabst Blue Ribbon
Beachbourbon is offline   Reply With Quote
Old 04-14-2019, 11:35 AM   #6
cavie's Avatar
The light coming on and then going out is supposed to be the indication that the heater did light. maybe bad board.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-14-2019, 12:16 PM   #7
Winter bypass
I assumed the winterize bypass valve is not still set to bypass. Did you check this?
Old 04-14-2019, 12:34 PM   #8
Igniter
Ray
I think this is the best suggestion, so far. You have gas ,ignition, that eliminates a circuit board problem. I would also take suggestion and clean igniter and/or reset igniter gap before proceeding any further. IMHO
Bytesponge
Bytesponge is offline   Reply With Quote
Old 04-14-2019, 01:44 PM   #9
Ray
RandK-M, WitchDoctor and Bytesponge, Thank you. I think this is the best starting point too and as soon as the driving rain and wind down here on the Florida panhandle coast let up a little bit, I'll go give it a try. Appreciate the time and though of your responses.
Old 04-14-2019, 01:45 PM   #10
I know. Leaves me scratching my head too. If the suggestion for cleaning and checking the gap on the igniter doesn't work, this is my next guess.
heater, water, water heater
