Old 11-06-2015, 12:03 PM   #11
No anode rod on Atwood water heaters.
hillsdaletc is online now   Reply With Quote
Old 11-06-2015, 12:10 PM   #12
stallsmi's Avatar
My tire tool that has a correct size to tighten the plug. It's one that has four sizes and is cross shaped. It's straight and long enough to get the job done. I find it easier than a ratchet and socket (plus I always carry one in my truck).
stallsmi is offline   Reply With Quote
Old 11-06-2015, 05:25 PM   #13
rracer5's Avatar
Originally Posted by SULTINI View Post
2 wraps with the tape is all you need. Anymore than that puts to much stress on the threads.
Tried just a couple wraps on HW heater plug & a few others I found leaking over the years. Always seemed to be plastic plug into metal giving problems. The only way I could get the leaks to stop was using several wraps of teflon. Maybe something about plastic shrinking with age and causing leaks. Must be why Atwood used pipe dope for a better seal.
I just didn't have any pipe dope on hand when I discovered the leaks.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-06-2015, 05:35 PM   #14
Ford Idaho's Avatar
Pipe dope lives up to it's nickname, any dope can put it on pipe!
It is fast and cheap (in no way related to the RV industry)
There IS a right way and a wrong way to use thread tape.
Three trips around the plug has been more than enough, once the tank gets hot it will swell/expand some so a little extra nudge might be needed.
Old 11-06-2015, 06:09 PM   #15
Cathcartww's Avatar
My last trailer had an Attwood with the plastic plug. As others have said, a couple turns of Teflon tape worked well for 3 or 4 ins and outs, then the threads seemed to wear out or something - also, as others have said, easy to cross thread. I always carried a spare just in case - pretty cheap insurance.
Cathcartww is offline   Reply With Quote
Old 11-07-2015, 02:17 AM   #16
I replaced my plastic plug with a small profile boiler valve. Makes it easier for draining.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 11-07-2015, 12:51 PM   #17
MNtraveler's Avatar
Interesting idea!
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-08-2015, 06:24 PM   #18
I agree with the two wraps but it doesn't hurt at all to put a little pipe dope over the Teflon, the combination does wonders if you have a small leak that the Teflon doesn't quite seal. Just a small amount is all you need, it has helped me on the job seal some stubborn leaks.
floridela is offline   Reply With Quote
Old 11-08-2015, 08:12 PM   #19
MNtraveler's Avatar
Thanks!
2016 Forester 2401R
heater, water, water heater
