Old 11-05-2015, 08:07 PM   #1
MNtraveler's Avatar
Atwood water heater plastic plug
Two questions, maybe related:
1) when this came out, it seemed to have some goop on it. When re-inserted should pipe dope or Teflon tape be added to the threads?
2) how tight to make it to prevent leaks but not damage the plastic? When I initially closed it fairly tight (maybe one thread showing), it was oozing just a small bit so I snugged it up a bit more and that seemed to do it.
PS: New 15/16" socket seemed to be the best tool - thoughts there? Not much room to maneuver...
PPS: In addition about worrying about being too tight, I'm worried about cross-threading this sucker. Seems like it could easily be done. Anyone had that happen?
OK, that's 4 questions! ☺️
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 11-05-2015, 08:21 PM   #2
Are you referring to the anode rod? If so, yes to the teflon tape. Tighten but not so much you can't get it off tomorrow if needed.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 11-05-2015, 08:23 PM   #3
Ford Idaho's Avatar
I use tape on my plastic plug, much easier to clean off the threads.
I start it with my fingers, if it starts easy then I use a socket and a 12 inch extension to go a little more before using the ratchet.
I check for leaks after the water is hot and then just snug it up till it stops leaking.
Old 11-05-2015, 08:27 PM   #4
rracer5's Avatar
When I had an Atwood, it had pipe dope from the factory. I cleaned that up and used teflon tape. It did ooz so, I re-wrapped the plug with about 10 layers of teflon tape. I thought about getting a metal plug but, the extra tape plus the heating of the water heater must have swelled the plug enough that it never leaked again.
If you use extra tape, that will help it feel snug enough and, as I said, the heat helped seal it up.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-05-2015, 11:36 PM   #5
MNtraveler's Avatar
The Atwood has a plastic plug, no anode rod, but it's the same location. Thanks for your comments.
Old 11-05-2015, 11:38 PM   #6
MNtraveler's Avatar
Thanks!
Old 11-05-2015, 11:39 PM   #7
MNtraveler's Avatar
Thanks - sounds like about what I did so all good. I'll try the extension rod for longer non-leveraged loading, if I can get it on.
Old 11-05-2015, 11:40 PM   #8
MNtraveler's Avatar
Thanks. I'll be giving the tape a try in the spring. Can't wait!
Old 11-06-2015, 12:18 PM   #9
2 wraps with the tape is all you need. Anymore than that puts to much stress on the threads.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
SULTINI is offline   Reply With Quote
Old 11-06-2015, 12:29 PM   #10
MNtraveler's Avatar
Makes sense, thanks!
heater, water, water heater
