Old 03-28-2015, 04:55 PM   #11
Scubanut's Avatar
I got rid of the plastic nut on my water heater and added a brass drain valve. No worries about stripping the nut and so simple to drain. Also did the same with fresh water tank.
Scubanut is offline   Reply With Quote
Old 03-28-2015, 07:23 PM   #12
banda's Avatar
I see the desirability of having a metal drain valve, but I have read that you can run into problems if you ever need to remove it (after a period of time) due to galvanic corrosion between the two dissimilar metals.
banda is offline   Reply With Quote
Old 03-28-2015, 07:31 PM   #13
Ford Idaho's Avatar
I have read the same thing, I just use the plug that it came with it has done just fine holding the water and pressure.
Just be sure you have is good and snug.
Old 03-28-2015, 07:45 PM   #14
I think you will find that a brass plug wrapped with Teflon will not experience any galvanic action in the time it is in the tank. You no doubt remove it to drain the tank when camping season is over.
Old 03-28-2015, 08:14 PM   #15
bubbles's Avatar
Ditto. Brass plug and 10 years with no issues. Did use Teflon tape.
Old 03-28-2015, 08:48 PM   #16
Scubanut's Avatar
Name:	ImageUploadedByForest River Forums1427593610.202506.jpg
I never thought it would be an issue, bought it from RV supplier and have used it in two trailers. But is something to think about and to watch.
anode, heater, water, water heater
