Old 10-20-2015, 08:39 PM   #1
Forester Fred's Avatar
B&B city water connection
Does the B&B city water connection have any type of pressure relief built into it?
I've read posts on various RV forums saying to press on the center of the inlet filter screen to relieve pressure in the line. Except, the screen in mine doesn't seem to move at all.
I wasn't sure if the B&B model has that capability or not.
(I searched, honest, but couldn't find anything)
This is the one on my motorhome, not sure if there's a backflow preventer on the back of it or it might just be the plumbing fitting.
2015 Forester 2301 - Chevy
Skip & Deb
Forester Fred is offline   Reply With Quote
Old 10-20-2015, 09:27 PM   #2
jtstromsburg's Avatar
The screen comes out. Just be gentle and pry it out. Then, you'll see the check valve "button" to press.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-21-2015, 08:19 AM   #3
Future Roo 23IKSS Owner
elundquist's Avatar
It has a built in check valve to prevent water from discharging when the pump has pressurized the system (boondocking).
I am guessing some are able to force the check valve open by pressing the inlet filter screen.
Erik Lundquist
iPhone 6S using Tapatalk
elundquist is offline   Reply With Quote
Old 10-21-2015, 08:22 AM   #4
elundquist's Avatar
To release the pressure in the system why not just open a fixture or the low point drains or the water heater p&t safety valve?
Erik Lundquist
Old 10-21-2015, 08:26 AM   #5
Please read the Post going on now (Put Antifreeze in City Water Con)! Youroo!!
Old 10-21-2015, 08:43 AM   #6
elundquist's Avatar
Ok to fill that line with AF. I have not done that before, but I could see the freezing problem.
What a great place to have a bust leak!
Good idea youroo. I would love to see the few that force open the check valve while pumping AF!
Erik Lundquist
Old 10-21-2015, 04:55 PM   #7
satdog01's Avatar
Does the same hold true for the black water flush? Thought I read where it had a check valve as well! If all the pressure is off the system by opening faucets and low point drains, would not the water in the city water and black water drain out on its own with out force? AF should displace most of the air when the pump starts filling the lines. Just a thought.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 267nights as camping buddy
Days camped in FR, 2011-12 = 77, ‘13 = 59, ‘14 = 39
‘15 = 52, ‘16 = 77, ‘17 = 81, ‘18 = 44, 2019 = 23
Retired :
satdog01 is offline   Reply With Quote
Old 10-21-2015, 05:58 PM   #8
The check valve for the black tank flush and the black tank flush system is separate from the fresh water system. My black tank flush check valve is under the bathroom vanity.
Skip & Deb
Old 10-22-2015, 08:26 PM   #9
Found it, thanks! Good news is there was no water behind it when I pushed the button. I already drained everything and pumped AF through the system then left the low point drains open.
Skip & Deb
water, water connection
