Don't put it on the pressure side (outlet side of the pump). Because the pump won't hold the pressure, when you use the pump, it will then never stay at pressure and will cycle ceaselessly! You must add it to the inlet side. It is up to you before or after the strainer. I'd say after, so you don't get large particles gunking up the one-way valve.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
