Old 10-29-2015, 08:36 AM   #21
I will look for the RV Digest. Yes, we're in Colorado until December, when we'll be moving to southern NV. Wanted to do it during school break.
TURBS, considering I'll be moving to 50-70-degree weather by January, I don't want to completely outfit my rig for winter, but, one, how would I find out/what would I look for to determine if my pipes are heated; and two, what can I do in this two-month time frame? Just read the sticky about winter living?
TIA!
whisperwhillow is offline   Reply With Quote
Old 10-29-2015, 08:42 AM   #22
Originally Posted by Bama Rambler View Post
Is the water backing up in the toilet? Maybe I missed it, but you said that you see it 4 to 5" below the toilet valve. Most RV holding tanks are only about 6" deep.
Have you had the black tank valve open the whole time?
You probably didn't miss it. My posts have been made on about two hours' sleep, so maybe I'm the one who missed part of the sequence.
So, when I FIRST noticed there may be an issue, I could see water pooling when I flushed. Since the black tank was registering as empty and I did an empty just in case it was misreading, I went to the Internet to see what I could do about a potential clog. The first thing I came across was two pots of boiling water. Now, two pots of boiling water later, the water, and everything else, is up to the top of the commode.
No, I don't ever leave my black tank open -- gray, yes; black, no. Should I not even leave gray open?
Old 10-29-2015, 08:42 AM   #23
TURBS's Avatar
Tia, if you have heated tank pads and outlets there will be switches in the convenience center with all your other switches.
Hopefully labeled "tank heaters"
You'll burn thru a ton of propane to keep that unit warm enough to hopefully keep it all from freezing.
Old 10-29-2015, 08:45 AM   #24
TURBS's Avatar
Leave grey closed till full as well.
It will help after draining black to clear the pipe.
I suspect your not using enough water when flushing.
Speaking of water, how are you getting water to the camper?
Old 10-29-2015, 08:47 AM   #25
Originally Posted by oxcamper View Post
Heated underbelly only means that the heat duct of the furnae goes through the same space as the water lines and tanks. The compartment itself is not actually heated.
I may have missed it, but what is the model of your unit?
It's a 2014 Forest River Cherokee Toy Hauler 377V.
Old 10-29-2015, 08:49 AM   #26
Oh, gosh, I don't have anything labeled like that.
Old 10-29-2015, 08:49 AM   #27
Boss Ox & Drovergirl
oxcamper's Avatar
There's no good way to actually see if your gate valve is opening or closing without crawling under the trailer. If there is underbelly covering, you won't see a thing without removing some of it. When you actuate the dump handle, (not knowing what unit you have ) do you feel any resistance to the handle as you pull or push it?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 10-29-2015, 08:51 AM   #28
Turbs I could be wrong but I think she said (Thanks in advance) not that her name is Tia? But it is a Nice Name! Youroo!!
Old 10-29-2015, 08:51 AM   #29
Okay, then, I'll keep that closed as well. That makes sense.
I'm hooked up to the water at the campground, but I turned it off as well as the pump so as to keep the flusher depressed all night without adding water.
Old 10-29-2015, 08:55 AM   #30
TURBS's Avatar
Won't they be turning off the water there soon?
Heck here in Iowa most cg's have shut water off to the park.
You can camp here but have to bring in your water.
