The pressure switch is on the pump output, so if you put check valve on output line of pump, then when it shuts off and water pump internal check valve leaks, pressure is lost between water pump and installed check valve and pump will start again. It will cycle on and off to keep pressure between pump and your installed check valve.
Fonzie
