Old 07-23-2012, 10:28 AM   #21
Originally Posted by wilderness503 View Post
Well I went down to the trailer this weekend to pull the fridge out, replace the plywood holding it up and scrub everything down to get rid of smell. When I went around to the back vent I noticed the smell a lot. A buddy of mine came over and said that it smelled like propane. Turns out that the old owner disconnected the propane fridge and tried to cap the old line. Well he didn't do a great job at it so propane was leaking out causing the trailer to smell. I shut off the propane, opened some windows, and turned on a fan. Within an our it smelled 10 times better in the trailer. Now that I know the problem I need to put a shut off valve on the old line or just cap it at the source. Thanks for all your input though.
You're lucky you didn't blow the whole rear end or side out of the trailer and seriously injure or kill someone when the frig tried to start on propane. You need to say a big Thank you to the man upstairs.
Old 07-23-2012, 11:11 AM   #22
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
And please get yourself a working gas detector!
dimurrrw is offline   Reply With Quote
Old 07-23-2012, 12:16 PM   #23
WOW!!! Glad no one got hurt! Also glad you found the source of the smell.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 07-23-2012, 12:21 PM   #24
TURBS's Avatar
whew ! good find !
Old 07-23-2012, 01:34 PM   #25
Alleged curmudgeon
Vern's Avatar
That is a seriously scary situation. Be glad you figured it out without incident, and be very thankful.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 07-23-2012, 01:39 PM   #26
cre10's Avatar
Wow, that's crazy.
2012 Chevy 3500 Duramax Crew Cab Z71 LTZ SRW
2012 Cherokee Grey Wolf 28BH
2011 F-250 6.2 Gas
2001 F-350 Powerstroke
1995 F-350 7.5L 460
Numerous Ford and New Holland Tractors up to 135hp. Bobcat 773.
cre10 is offline   Reply With Quote
Old 07-23-2012, 03:13 PM   #27
Yea we were really lucky.
wilderness503 is offline   Reply With Quote
Old 07-23-2012, 03:36 PM   #28
Rockinwood's Avatar
Shaking my head..so glad you did not get hurt, and you found the problem! Now go to the previous owner, and give him a good kick in the rear!
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 07-23-2012, 04:19 PM   #29
punkaccountant's Avatar
Do you have a propane detector? It should have gone off if the propane was leaking inside the trailer. If not or if it doesn't work, please get one ASAP. After all it was used and if that is indicative of the work the previous owner did then you want to keep yourself and family safe.
http://www.forestriverforums.com/attachments/signaturepics/sigpic20864_3.gif
2013 Rockwood Mini-Lite 2306
2011 Ram 2500HD Hemi
punkaccountant is offline   Reply With Quote
Old 07-23-2012, 06:14 PM   #30
I'm glad you found the propane leak and have it fixed, or will have soon. One question I had and have not read the answer to this: Was the replacement fridge/freezer a "household type" or an "evaporative type" as was in the unit to start with? IF the replacement unit is a household type then you would likely have a pan sitting directly on top of the compressor which catches the water draining off of the evaporator. This water should evaporate from the heat created by the compressor. BUT--sometimes this water will sit when the unit is not running, collects dust, bugs, etc., and will smell terrible when the compressor starts back up again and creates the heat necessary to evaporate the condensate in the pan. I have a problem with a fridge in my shop each summer when bugs/lizards get in there, die off, the water totally evaporates and the compressor literally bakes these bugs/lizards. Really bad smell
Thurman is offline   Reply With Quote
