Old 04-11-2019, 09:58 AM   #1
Badlands SD blizzard. Issues
Am in my Coachman Leprechaun 220QB for a seasonal job in the Badlands. Anticipated some cold nights for a while but not a blizzard. My tank was spray foamed at the dealership before leaving Florida and they told me to run my hot water heater continually if I got into freezing temps. Have been running my water heater, furnace at 66 degrees, dropped it to 64 degrees last night to conserve propane. Turned on water pump this am and no water even though tank is 3/4 full, frozen I'm assuming. I opted to fill my tank prior to blizzard as opposed to remaining connected to water due to water issues on site. Projected temps for my area are below freezing at night and 30s during the day for several days after storm passes. I can't drive out in my car for a while due to road conditions.
Advice for this Florida gal? I'm in quite the pickle.
judyoshi is offline   Reply With Quote
Old 04-11-2019, 10:32 AM   #2
Old Forester's Avatar
It's likely the whole tank has not frozen, but a line between it and the pump. Since its PEX, you'll probably just have to wait for it to thaw and then carefully evaluate it once it thaws to ensure it has not split the line and will leak.
If you knew just where the frozen line was, you might tease it with a hairdryer on LO. In the future, keep in mind that moving water will prevent it freezing. See if you can fab a line from a faucet right back to the fresh-water tank and "loop" it through the warm quarters. For water right now, you can thaw snow on the outdoor kitchen cooktop if equipped. Banking the outside of your coach with snow may help hasten the thaw. That prairie wind suck the heat out of everything. PS Using any heat source like a hairdryer needs extreme caution and you can't be too careful. Good Luck
Old Forester is offline   Reply With Quote
Old 04-11-2019, 10:33 AM   #3
Sounds rough. Collect some snow for water
Did you open any cabinet doors where water lines are? That might help if a line has frozen. Up the thermostat more and hope it isn't the tank. I would think you tank isn't frozen solid..maybe slushy. Try keeping a line open as you up the temp in the unit and as the temp rises outside. You need to get some water movement to help the thaw and keep from freezing further.
I know I'm not really much help. Maybe others have some advice based on experiences.
Best wishes. Feel for you.
2019 Flagstaff E-Pro 14FK
JS Stanley is offline   Reply With Quote
Old 04-11-2019, 10:37 AM   #4
A hairdryer is a good idea. Try using it on water lines. Heating some of the water may help get some flow. Try all the lines you can get to. May have to remove some panels.
I would suspect the line is frozen near the tank. Not sure where you tank is though, but that's my guess.
Old 04-11-2019, 10:43 AM   #5
Oh, just a thought. Try all faucets as the pump only runs to supply demand. A line to the kitchen sink might be frozen but one supplying the bathroom might not be, so check every faucet. All faucets = no water, probably frozen between tank and pump.
Old 04-11-2019, 10:46 AM   #6
Thanks everyone for the tips.
I checked plumbing under kitchen sink, not cold. Under bathroom sink cold. Running space heater towards it as we speak. I would increase temp on furnace but am not sure how much propane I would use, currently set at 64.This is all new to me.I'm not using propane to cook. Have some meals I prepared in advance and am using microwave. Have bottled water. There was no way to outrun this thing. Learning as I go.
Thanks again all.
Judy
Old 04-11-2019, 12:28 PM   #7
Use a drop light if you have one.
I have found a good old 60 watt light bulb in the water pump cubby will keep it and nearby water lines from freezing. Good luck.
Aso, for heating in general - turn off one of your propane tanks. That way you will know when first is empty and can conserve using second until you can refill.
SweetOleBill is offline   Reply With Quote
Old 04-11-2019, 12:38 PM   #8
Just to be sure... have you used the on-board pump before?
Do you hear the pump run when there is no water.
Just wanting to make sure your pump runs before we all come to the conclusion something is frozen.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 04-11-2019, 12:38 PM   #9
You are definitely in a pickle, but you can get through it.
My recommendation would be to open all the faucets in your rig and keep them open. Water expands as it freezes and keeping the faucets open reduces the pressure on those lines (gives air a way to escape and decreases pressure in the lines). At this point, increasing the heat in your rig probably isn't going to help defrost those lines. Those lines are probably frozen in an inaccessible place.
You're doing everything right... space heater, using electric instead of propane, using bottled water. Not much you can do until this unexpected storm passes and the temperature gets above freezing.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 04-11-2019, 01:55 PM   #10
Don’t forget to open all cabinet doors that might have water lines running ac,Ross the back.If you have no water at any faucet then you are froze up in the main line to or from the water pump, locate pump and start thawing there.
Chuck.virginia is offline   Reply With Quote
