Old 03-11-2014, 03:13 PM   #1
Somewhat right of center
Crabbyguy's Avatar
Barker Portable Tank
Ok, I just received the Barker 42 Gal portable black water tank and have one question. It's sturdy and built well with the pneumatic tires. The only thing I don't like is the metal hammered on cap that holds the tires on. Has anyone heard of these things failing?Considering the weight (well over 300lbs when full) I'm concerned they will pop off. Thanks. Pic attached.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Crabbyguy is offline   Reply With Quote
Old 03-11-2014, 03:20 PM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Mine is going on 8yrs old...so far no issues with wheel cap or anything else-great tank (I assume it gets used about 2 camping trips/yr as the other trips are full hookup)
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-11-2014, 06:14 PM   #3
Crabbyguy's Avatar
Thanks Cajun.
Old 03-11-2014, 06:28 PM   #4
Oklahoma Proud
MillerTime's Avatar
You can always drill an 1/8 hole thru the axle (and maybe the cap at the same time) and run a cotter key or hair pin clip in it. I do it all the time on stuff like this!
-the pic is of my generator axle
MillerTime- Future Sabre Handler!!
Old 03-11-2014, 09:00 PM   #5
I had 25 gallon 4 wheel for many years and love it upgraded to 35 because of height of tote and love it. Have had 3-4 years and use it all the time for my camper and friends campers.
CincyED is offline   Reply With Quote
Old 03-11-2014, 09:13 PM   #6
I have the same tote(42 gallon) and made my mods to it before Barker started adding the pneumatic tires. I cut my axles and used the same caps as they do now from the Ace Hardware store. Haven't had any issues yet.
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
Old 03-12-2014, 07:57 AM   #7
Crabbyguy's Avatar
Thanks all.
Old 03-12-2014, 08:10 AM   #8
cogito ergo moo
Cowracer's Avatar
This will put your mind at ease. Try to take the cup off yourself. I think you will be surprised at how difficult it will be.
I had a similar setup on a hand truck, and I wanted to replace the wheels. It took hammers and chisels and other implements of destruction to get them off.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 03-12-2014, 08:29 AM   #9
Crabbyguy's Avatar
Thanks Cowracer. That does put my mind at ease. I started this thread cause I was wondering if I really needed to do the cotter pin mod. Truthfully, I didn't feel like doing it without checking other people's experience with them. From what you all said so far, the mod isn't necessary.
Old 03-12-2014, 07:38 PM   #10
Mind never have. Had the wheel break, replaced both with metal wheels. Lowes has the push on holders if you want to pick up some extras.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
tank
