Old 08-23-2009, 05:24 PM   #1
Bath Holding Tank Question
We have a leak in our 2001 Cardinal 32 XL bath holding tank. When there is water in the tank, it leaks out of the drain line hole. How would I proceed to check out the origin of the leak?
Thanks!
George
Cardinal Clan is offline   Reply With Quote
Old 08-24-2009, 01:55 AM   #2
It could be the valve is not shutting all the way may be something in it or the valve is just going bad just a thought
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 08-24-2009, 08:07 AM   #3
Head Rambler
If it's leaking out of the drain line then the valve is leaking by. There could be something in the valve preventing it from closing all the way. There should be 4 bolts holding the valve body in the line remove them "After you've drained the tank" and the valve should come out of the line. You can then replace it or clean and lube it and put it back.
Gotta go campin!
Old 08-24-2009, 08:30 AM   #4
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
And wear rubber gloves. Those tanks never seem to empty completely.
dimurrrw is offline   Reply With Quote
