Old 01-10-2018, 11:06 AM   #1
Dr Travel
Bathroom faucet - Now I'm in trouble!!
Okay, our nickel-dime bathroom faucet hot water handle just disintegrated one day. No way to fix or replace, apparently. Talk about cheap stuff. shame on you, FR.
anyway, trying to change this faucet is virtually impossible. The faucet is up against the bathroom wall, and access from below is blocked by the sink, water lines, and a shelf. The cabinet, countertop, and shelf is pretty nigh impossible to remove as the screws that hold them in place cannot be accessed.
I was able to break free the connector to the cold water faucet, but it doesn't turn to complete the disconnect. Borrowed a plumbing tool to help with the impossible angle, and no luck. Cannot break free the hot water connection; it is simply on there too tightly. And I tried my friend's plumbing tool to grip it and break it free, but no luck. Almost impossible angles to try to get at these dang connections. I bought a replacement faucet at Camping World, but now appears I'll have to return it since there seems to be no human way to remove the existing faucet. If it sounds like I am about to snap, and am thinking the dunces at FR need a lesson or two in design, you are correct. I promised my wife when she left at 7 am this morning that when she got back at 1 pm it would be job done.
If I am "stuck" with this cheap crap, then it is just a matter of time before the cold water handle disintegrates like the hot water handle did. Then I am very serious trouble. There is no brand name on the factory installed faucet, so no way to get the parts to fix that - if such a thing was possible (highly unlikely.) Sure wish FR/Rockwood put more quality fixtures in with easy access for repairs. Pretty easy to do, and would happily have paid another $50 for my rig to have it the right way instead of this insanity.
Okay, rant over - anyone got a brilliant idea to save me and my faucet??
Homesick for places we've never been.
Fulltimers since 2014; still going strong in our RW Sig Ultralight Fiver. Have towed the Rockwood 27,000 miles with nary a hiccup. (Except for when participating in happy hours)
robsshots is offline   Reply With Quote
Old 01-10-2018, 11:19 AM   #2
Pictures?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 01-10-2018, 12:02 PM   #3
Dr Travel
Pictures
Good idea...coming right up.
Old 01-10-2018, 12:10 PM   #4
Dr Travel
Photos
Ok, how do I upload photos???
Old 01-10-2018, 12:12 PM   #5
Dr Travel
Ok, got it - photos attached
Photos of my predicament
Old 01-10-2018, 12:16 PM   #6
cavie's Avatar
While we wait for the pics I'll say this. It is not just with FR. All RV's have this issue. It's all about Cost and weight. A few pounds here a few pounds there. It all adds up. Replacement faucets are easy to find. Google and Amazon are your friends. Youtube will be very helpful also. Is there a thick base on this faucet to indicate that it may be surface mounted held in place with a couple of screws that you may not be seeing. That's why we need pics. If it's in the wall I sure there is a removable panel on the back side of the wall. Trailers are an education and a challenge. it's fun to beat that challenge.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-10-2018, 12:19 PM   #7
NMWildcat's Avatar
First I would try someone with smaller hands. Next, I would look at removing the sink itself. If all else fails, cut the supply hoses, hopefully you can then use the hose to help twist off the anchor nut and connection to faucet, replace the faucet and reconnect hoses with pex union/coupler. Or better yet put a fitting on the pex and just use standard sink supply hoses to reconnect.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 01-10-2018, 12:23 PM   #8
Dr Travel
Thanks for the response, but I used to sell these rigs and am very familiar with the nickel-dime crap the manufacturers use to justify stupidity.
As you'll see from the photos, there is no panel to be removed with a couple of screws. The shelf cannot be removed because the sewer pipe runs through it.
I agree that it is fun to beat the challenges presented by dumb engineering and stupid 'cost cutting" or "cost containment." That's why I do all of my own repairs, like replacing my TV antenna. But this sucker has me stumped, ergo my appeal for help. The wall at the back of the sink is the exterior wall. NO ACCESS.
Old 01-10-2018, 12:30 PM   #9
bubbles's Avatar
Pull the sink.
Old 01-10-2018, 12:30 PM   #10
NMWildcat's Avatar
Another idea. Get a tool like this to remove faucet nut, then pull up faucet to remove hose connection if there is enough play in supply hoses.
https://www.google.com/amp/s/www.fam...g-faucets/amp/
bathroom, faucet, roo
