Old 01-29-2019, 09:45 PM   #1
Bathroom faucets just trickle
On our first trip with 2019 Freedom express pilot. It was winterized and I sanitized the piping except for bathroom faucets and showers. Kitchen faucets and toilet work fine. The others just trickle. Any ideas? Thanks.
sdaldridge is offline   Reply With Quote
Old 01-30-2019, 12:29 AM   #2
bikendan's Avatar
Remove the faucet strainer and you'll probably find construction debris clogging it.
Equalizer WDH
Old 01-30-2019, 06:00 AM   #3
Take out the restricter and throw it.
ijon is offline   Reply With Quote
Old 01-30-2019, 06:22 PM   #4
Spot on. Found chunk of plastic in the center hole. Also were four wire screens. I only used one and have spares. Thanks.
Old 01-30-2019, 06:24 PM   #5
Great idea. Found debris plugging it up. Tried without it but flow was too uncontrolled. Thanks.
Old 01-30-2019, 06:35 PM   #6
Flybob's Avatar
Having the screen in the faucets is not normally an issue. It is only an issue if there is crud in the lines. Do not drain water heater via the low point drains. It draws the crud from the water heater and some of it will remain in the lines. The next time you use water, it will travel to the faucet screens.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-31-2019, 01:57 PM   #7
MilCop4523's Avatar
First trailer we owned had no water. the pump filter was literally plugged with sawdust. no idea why the QA QC people do not test this along with satellite cable connections which never seem to work in the correct rooms labelled or at all.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 01-31-2019, 03:35 PM   #8
PlanoPaul
Don't use low point drain for draining water heater
This is a great tip from FlyBob.
I made that mistake last year.
pdbelew is offline   Reply With Quote
Old 01-31-2019, 03:55 PM   #9
cavie's Avatar
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
bathroom, faucet, roo
