WOW! just got back from trip in so. cal.
Got through it but not pleasant. Took shower first morning and opened shower door to a flooded bath floor and part of main quarters. glad of short shower or entire motorhome would have flooded. Model I have has water pump and drain under shower pan. Very tight quarters to see under. Connections seemed tight. No small leak
Seemed to be vast majority of water was dumping outside under rig and inside flooring. Ideas?
I had the trap break on ours. Replaced it and noticed not very much support of the floor. Used blocks of dence shipping foam to support the floor and pan, but could still remove if there was a future problem.
About 20 mins ago I located another leak in my shower. I believe it's coming from when the water runs onto the hot and cold handles and its leaking behind the wall and then into our living room. Check all the caulking in and around the entire shower. This is the second leak. First leak I had to actually stand inside the shower and spray water until I found the the bottom lip was not sealed correctly and water was running down the inside of the door and then up and over the outer lip. Has been a mess. These are a few things to check.
Ours was a connection underneath the shower that had become disconnected. Removed the panel on the front of the shower near the floor and found a younger and more nimble friend who managed to reach under there and reconnect and seal the pipe.
