Old 12-30-2017, 09:56 PM   #1
Berkshire PSI?
Does anyone know what PSI the plumbing is rated for in a 2009 Berkshire motorhome? Considering a stronger water pump that has 60 PSI and 5.5 GPM. Currently have a 3.3 GPM and water pressure seems a bit weak.
thomshepherd is offline   Reply With Quote
Old 12-31-2017, 03:06 PM   #2
You should not have a problem, I set my adjustable pressure regulator at 60 for campground water.
What you may have a problem with is getting enough water to the pump. If your suction hose from the tank is 1/2 inch it might not do it.
Rich5117 is offline   Reply With Quote
berkshire
