04-22-2019, 07:44 AM
#21
Well thee you go..............several methods:
Backfill Valve
Backfill adapter
Hose in toilet
Pour water in toilet
Put wand in toilet
Take your pick. In my opinion they will all work.
I use one of these methods but I won't say which because I dont' think it matters what you do, so long as you do a thorough job.
There is one I won't dignify with even a mention. I know it was offered in jest.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
04-22-2019, 08:22 AM
#22
Originally Posted by 7Murph7
I am new to RVing and I have a 2010 Heritage Glen Wildwood. Which does not have a hose to backwash my black tank to make sure that is really clean. Is there another way to make sure you get all the waste out of the tank. I was thinking of sticking a hose in the toilet and letting it get 3/4 full and then opening up the gate. To make sure everything is out of the tank.
I think a lot depends on the shape of your Black Tank,,,
With our last Trailer the Toilet Wand worked Great !!!
I think I have seen them @ Wally World !!!
04-22-2019, 08:35 AM
#23
2011 Traverse LT, 3.6L, FWD
04-22-2019, 09:25 AM
#24
we always have or keep water in the tank if that makes sense ... after we dump at site with a good back flush we add water and a new drop bag for the ride home and it is ready to start next trip ..... we always flush twice after each use so I keep a eye on tank level ... we are new but I think plenty of water is the key ... we are lucky to have what seems to be a really good black tank back flush on the new Rockwood ...
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
04-22-2019, 09:49 AM
#25
Originally Posted by Jhut
When I bought mine, the dealer said to make sure I have plenty of water in to start. He recommended at least 10 gallons. Which would help in the emptying process.
If you fill it with 10 gallons when you go out boondocking, there goes a fourth of my tank on our Class C
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
04-22-2019, 09:55 AM
#26
We travel home with a few gallon of water & some laundry detergent & some Calgon !!!
04-22-2019, 12:36 PM
#27
X2 - Geo Method!
https://sites.google.com/site/cbruni/
04-23-2019, 03:34 AM
#28
but if you dont' put any water in there you can end up with a "Brown Pyramid".
04-23-2019, 08:32 AM
#29
what I am saying is you don't need 10 gallons. I use this stuff: TankTechsRx . It works great. We go out for about 4 days at a time, so between number 1 and 2 there will be plenty of water in there.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
04-23-2019, 10:14 AM
#30
Originally Posted by itat
I thought that too when I first saw it, but the one he uses in the video is different than the one Anderson posted above. The one posted above has a built in valve that allows the water sprayed into the tank to stay in the tank.
The one in the video the water just sprays in and then comes right back out.
So if he's using it mostly to fill/dump his black tank several times, it probably works just fine.
04-23-2019, 11:30 AM
#31
Our Class C has a built-in tank flush that I hook up a hose to ( not white lol ). It also has a sprayer in the bathroom.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
04-23-2019, 11:36 AM
#32
Canadian Member
The Rhino Blaster that Anderson15 was referring to is just a clear 45 degree bend with a garden hose hose fitting, the same as the HydroFlush thing in the Fit RV video I linked to. There is also a Rhino Blaster Pro that has a 3" valve built in which would be basically the same as the setup in the Fit RV video, but in use there is already a 3" valve on the black tank dump pipe. Either would slowly fill the black tank but really offer no jetting inside the tank - just a refill and drain. So its much less effective than a wand or Tornado device that jets water in the tank.
04-23-2019, 01:15 PM
#33
He posted a pic of the Rhino Blaster Pro with the built in valve.
The one in the video was more like the regular one without the built-in valve. The valve in the pic represents the one on the trailer itself.
It will never fill the tank because you have to keep the valve open to get the water into the drain and it just drains right back out again. He even shows this in the video. Only the pro version allows the tank to fill because the jet is behind the built-in valve.
Agreed. Although as mentioned above, you might have to drag a hose through your trailer to do that. Not to mention the fact that some of those spray wands only work if you have a straight drop into the tank. Although they do make flexible ones.
04-23-2019, 01:21 PM
#34
How did we know she didn't have teeth?
04-23-2019, 01:26 PM
#35
04-25-2019, 06:31 PM
#36
Put approx 1/3 tank of water in, add 10 lbs of ice, drive 10 miles over bumpy road, lots of start stops, drain ... repeat until your levels show empty!
No toothbrush required!
04-25-2019, 06:48 PM
#37
Black water
I read somewhere a guy would dump 5-10 lb bag of ice in the toilet before heading to the campground
#38
You just beat me!!
04-25-2019, 06:52 PM
#39
Yes, thank you
Chris
2020 Grand Design 337RLS
2019 Rockwood 2608BS (Sold)
2005 Rockwood 2516G (Sold)
2018 Chevy 2500 6.0 / 4.10's
04-25-2019, 06:53 PM
#40
Attachment 202587
Wrong, it has its own gate valve. It will fill the tank...
How about ACTUALLY looking at the picture.
Chris
