Old 04-20-2019, 04:31 PM   #1
Best way to really clean black tank
I am new to RVing and I have a 2010 Heritage Glen Wildwood. Which does not have a hose to backwash my black tank to make sure that is really clean. Is there another way to make sure you get all the waste out of the tank. I was thinking of sticking a hose in the toilet and letting it get 3/4 full and then opening up the gate. To make sure everything is out of the tank.
7Murph7 is offline   Reply With Quote
Old 04-20-2019, 04:40 PM   #2
they sell some fancy gizmos that go down the toilet and spray water around but I've always felt like that is prob over kill. If you don't have a black tank flush fitting your idea is probably good enough.
Kimber45 is online now   Reply With Quote
Old 04-20-2019, 04:43 PM   #3
When I bought mine, the dealer said to make sure I have plenty of water in to start. He recommended at least 10 gallons. Which would help in the emptying process.
Jhut is offline   Reply With Quote
Old 04-20-2019, 04:43 PM   #4
Herk7769's Avatar
Just don't use the white hose or the one you fill your fresh water tank with.
HAM CALLSIGN - KC3FFW
Old 04-20-2019, 04:54 PM   #5
Anderson15's Avatar
Yes, you can stick a hose down the toilet, let it fill up to 3/4 or so and then dump again. I've used this method, years ago, on our first TT. I would fill/dump 3 or 4 times this way and never had an issue with the black tank or with the tank gauges.
My new TT has a black tank flush, but I don't use it.
I use a Rhino Blaster. Much easier to back flush the black tank. I do the same procedure - dump, fill, dump, fill, dump. Works well and much easier than dragging a hose through the camper.
There are several different brands that work the same way.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Chris
2019 Rockwood 2608BS
2018 Chevy 2500 6.0 / 4.10's
29 camping nights in 2019
Anderson15 is offline   Reply With Quote
Old 04-21-2019, 06:40 AM   #6
Thumbs up
Thank you everyone for your in put.Anderson 15 I like your idea I will pick one of them up from Amazon Thanks for the help.
Old 04-21-2019, 01:42 PM   #7
CaptnJohn's Avatar
Just grab your wife's toothbrush and stick your hand down and scrub. Use gloves and make sure to rinse her toothbrush really well before putting it back.
2019 Montana 3761 FL
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-21-2019, 01:51 PM   #8
My wife said she fails to see the humor.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 04-21-2019, 02:59 PM   #9
Swampy's Avatar
7Murph7,
I can think of 2 simple and cost effective things you can do.
1) Get a clear sewer elbow (either 90 or 45 degree) put this on the end of the dump plumbing on the RV before the stinky slinky. 2) Get one of the Camco tank rinsing wands to stick through the toilet and into the black tank when you are dumping the black tank. (Do Not use your fresh water hose on this!)
You can purchase both at Walmart or Amazon, under $10.
Another thing you can do is use some water softener and liquid detergent down the toilet to keep your sensors working. (Google the GEO Method).
Hope this helps . Good Camping Swampy
Jim (Swampy), Susie, Jimmy & The Chihuahua Crew
2008 Chevy Silverado LS, 4.3L, V6, 2WD, 3.23:1
2014 287 BHBE; 1981 JayRaven: Predator 3500i - Call Home Pearl River, Louisiana. on The Honey Island Swamp
https://www.forestriverforums.com/at...pic81807_1.gif
Swampy is offline   Reply With Quote
Old 04-21-2019, 03:23 PM   #10
CaptnJohn's Avatar
Since when is a solution supposed to be funny?
2016 F350 diesel
black, black tank, tank
