Old 06-21-2018, 05:35 PM   #1
125992's Avatar
Black and gray tank during two months of inactivity
We have completed a 31 day trip (our first outing with our first RV) and will not be using the RV for the next two months. We need to work now.
How do I maintain the RV in my driveway for the next couple of months before we get out again?
Should I do anything special with the black (no solid waste - I hope) and gray tanks?
What should I do with the batteries?
Thanks!
Bill
2015 Coachmen Leprechaun QB220 (purchased April 2018)
2018 Days Camped - 35
125992 is offline   Reply With Quote
Old 06-21-2018, 06:55 PM   #2
Wow 31days. That is good living for sure.
Assumptions;
1) you drained your waste tanks
2) it's not going to freeze before you go out again
3) you removed all of the food and trash from the RV
4) there is a couple inches of water in the toilet bowl to keep the seal moist
5) left bath vent open just a smidge for venting
If it were me, I would just disconnect the battery and close it up.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 06-21-2018, 07:26 PM   #3
fonzie's Avatar
Drain your fresh water tank, trailer low point drains and water heater.
Fonzie
Old 06-21-2018, 08:42 PM   #4
A32Deuce's Avatar
By pass the heater and drain via the anode rod or drain plug. Puts junk that is in the tank from getting in your lines. There is some calcium build up in the tank, maybe. Then just open the low point drain and fresh water tank.
A32Deuce is online now   Reply With Quote
Old 06-21-2018, 09:43 PM   #5
I am curious as to why you would drain fresh water tank and hot water tank if not winterizing. I am thinking there should be enough chlorine to keep the water good for a couple months. Have you guys had issues?
Hoping the OP will tell us about those 31 days...hope it was for fun and not work.
Old 06-22-2018, 10:30 AM   #6
125992's Avatar
I'm curious too about draining fresh and hot water tanks.
Also, I posted a post trip summary with pics under another topic. I think it is under "On the road." Maybe that was not the best place to put it but I didn't know where to summarize our trip. Suggestions?
Bill
Old 06-22-2018, 11:00 AM   #7
Kaadk's Avatar
Not suggesting full winterization, just some preventative measures to make sure you don't end up with stagnant water. City water will have chlorine, but even that will decay over time. Think of a pool. It gets way more dosage of chlorine than your standard tap water, but if you don't maintain it, after 2 months you're going to get algae growing. Now think of that same water sitting in your tanks, with a much weaker concentration of chlorine.
We will leave water in our HWT all season, but we're out at least every other weekend, so it's always getting fresh turnover. If I was going to let it sit for any longer than the at most 11 days between trips, then I'd be draining it.
Old 06-22-2018, 11:11 AM   #8
Prime Member
Remove anything perishable.
Remove anything else you don't want left in the camper.
Rinse and drain your waste tanks.
Turn off refrigerator.
Turn off propane at the tanks.
Leave refrigerator door open.
Give the interior a good cleaning.
Place a large bucket of DampRid inside.
Plug camper in. Make sure your main and your 12V converter breakers are on. Turn the rest off.
Close and lock the door.
If you camper is parked in the sun, I would also consider covering it.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 06-22-2018, 11:29 AM   #9
A32Deuce's Avatar
Another thought. Not all camp grounds are on Municipal water. Many use well water. In that instance or just time between trips, I would also drain the fresh system!
Old 06-22-2018, 01:56 PM   #10
That is good enough reason for me to drain!
black, tank
