Old 09-08-2013, 01:06 PM   #1
Ruger77's Avatar
Black tank
My black water tank still shows full after I emptied it! Camper is a 2014 Puma 23FB! What do you guys think?
2014 Puma 23FB
2012 Dodge Ram
Ruger77 is offline   Reply With Quote
Old 09-08-2013, 01:09 PM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Usually means the probes inside the tank have deposits of paper and/or other debris stuck on sensor...which will give you a false reading...happens all the time.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 09-08-2013, 01:12 PM   #3
Ruger77's Avatar
What should I do fill with water and try to flush it?
2014 Puma 23FB
2012 Dodge Ram
Old 09-08-2013, 01:26 PM   #4
kc8lvy's Avatar
If you have a Black water flush on your trailer try that if not there is a clear elbow that has a water hose hook up that attaches to your waste dump or people have suggested putting a bag of ice and water down your toilet after you dump and then drive around a bit. There are lots of good suggestions on how to keep your tank clean just use a search and you will find lots. I try to flush mine out as often as I can. Also search for the Geo-Method it seems to work quite well and is easy to do.
2004 Dodge Ram 2500HD Cummins
2013 Cedar Creek Silverback 33rl
kc8lvy is offline   Reply With Quote
Old 09-08-2013, 01:27 PM   #5
Camper Less Camping
You can try that if tank has not setup too long since your last emptying...most folks on this forum will do a Calgon soap solution in their tank and while driving down the road, it'll help loosen the debris...then empty out once you get home.
Some do a bagged ice method also to help scrub the walls while the camper is in motion...use the search button on this topic & you'll get a ton of info on this subject
Personally, I wouldn't worry much about it...takes a lot longer to fill up the black tank vs the grey tanks on a camping trip.
Old 09-08-2013, 01:28 PM   #6
GEO method worked for me!!!
RV Tank Sensors &The GEO Method | Wheeling It
Hudlow is offline   Reply With Quote
Old 09-08-2013, 02:05 PM   #7
Witch Doctor's Avatar
Originally Posted by Hudlow View Post
Thanks, I woundered how that works, do you still need odor control or not? Or is that just for cleaning....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-08-2013, 02:29 PM   #8
kc8lvy's Avatar
I use the Geo Method at least every other trip sometimes every trip. I only use odor control if we camp for more than 3 days. I have 1 more camping trip planned before the cold weather hits (I hope). On my way home I am going to use the geo method on all my tanks to get them clean before my camper gets winterized.
Old 09-08-2013, 07:57 PM   #9
coderider's Avatar
I have been using the geo method since I got my 5'er. I do it everything e I stop at a dump station and I'm sure to use my internal flusher to spray the inside of the tank until I get "clear" liquid out and no "bits" passing by.
Have not had problems with odors and my sensors seem to be reading pretty well.
coderider is offline   Reply With Quote
Old 09-08-2013, 08:34 PM   #10
Oaklevel's Avatar
This is a normal occurrence......... You can try the above methods........... After having sensors in a couple trailers I mainly go by what is normal for us as to when to dump the tanks..........
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
