Old 02-23-2014, 07:10 AM   #1
black tank agitator?
any of you folk stay parked up for long periods of time in your van/trailer/5th wheeler?
we've been parked now for 2 1/2 months. I am hooked to a working septic tank where we are. grey water is always open to the septic, but I leave the black tank closed until it needs draining. we are having problems with waste and toilet paper building up enough to block the tank drain and well basically not drain. I've made a pressure pipe set-up to wash out the tank and flush it all out. but...
I feel if I can have some sort of agitator in the tank to 'mush' up all the waste it'll just flow on out and empty with-out any dramas.
so has anyone heard or done something like this?
whilst we are on the move with the blue solution in the tank we find the movement of travelling is enough to 'mush' it all up for good tank emptying.
thinking I will have to make something myself. which I like to do anyways.
cheers.
JohnW is offline   Reply With Quote
Old 02-23-2014, 07:21 AM   #2
Todouble's Avatar
Some people use ice cubes and take it for a drive. Bangs arounds and agitates it some. Not sure if it will work for ya. Are you in a cold climate? Any chance it's frozen at the valve?
Todouble is offline   Reply With Quote
Old 02-23-2014, 07:58 AM   #3
yeah I've read about the ice cubes. I'm not going to pack up the set-up every time I want to drain the black tank to go for a drive. like I said when we are on the road there is no issue as it all gets sloshed around.
not that cold down here (south east of western Australia) though the missus does complain she's 'cooold' now and then when it gets to 11 degrees. hahaaha.
I am leaning more towards a submersible 12volt agitator. I'm a 'handy' type of bloke, so I think I will just have to research and build something.
thanks for your reply.
Old 02-23-2014, 08:33 AM   #4
Plain Old Member
First, we use the Geo Method in the tank. A google search will turn up what it is. Basically the use of water softener and detergent. Water softener keeps anything from sticking to tank walls, detergent cleans.
https://sites.google.com/site/cbruni/
I also read on here the other day about a product called Unique Digest-It tank treatment. From the posts I read on here, this stuff works quite well.
RV Digest-It Holding Tank Treatment
It's mentioned in this post: Replacing black water sensors
Scroll down to the one by herk. I just so happened to find some at our dealer so figured I'd have it on hand to try it out. Sounds like it eats everything.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 02-23-2014, 10:34 AM   #5
fonzie's Avatar
Probably you know, but first rule of thumb is water,water,water after each use.....then the other stuff mentioned here..........
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 02-23-2014, 10:42 AM   #6
Ford Idaho's Avatar
Agreed, one of the more common problems is some people do not use enough water when flushing.
Old 02-23-2014, 10:46 AM   #7
lots of water before first use, bingo!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 02-23-2014, 10:47 AM   #8
Water,water,water! Your water turns Counterclockwise, going down the drains,Yes? Youroo!!
Old 02-23-2014, 10:58 AM   #9
DAISY BOYKIN's Avatar
Use a good septic paper
When being parked for long periods of time, you should use a "SEPTIC TANK SAFE" paper. I tested several toilet papers by filling a glass with water, then insert 2-4 squares of "T" paper in the water. Time how long it takes to break down in the glass of water. The faster the "BREAK DOWN" the better the paper is friendly to your blank tank. I found one paper that was labeled "SEPTIC SAFE" to break down as quick as seven minutes. Another one took two days before it began to break down and was labeled as "SEPTIC SAFE".
You can purchase a plastic wand that will fit on the end of a hose to help flush the black tank. Or you can make one from PVC, CAP, HOSE FITTING with holes drilled in the cap.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 02-23-2014, 11:16 AM   #10
Herk7769's Avatar
I know no one like to dump the black tank (even in hookups), so they have a tendency to skimp on water in the flushes.
Resist this tendency. Water, Water, Water and more Water.
HAM CALLSIGN - KC3FFW
black, black tank, tank
