Old 08-21-2016, 11:20 AM   #1
Black tank brain fart
Well as the bone head I am I left the blank tank flush hooked up for hours. It overflowed out the roof vent but pushed the pipe out of the roof any one know why that would happen and if I should worry about just pushing it back down?
Mattman06 is offline   Reply With Quote
Old 08-21-2016, 12:07 PM   #2
Devilscreekw's Avatar
Always wondered what would happen if one did that. Don't have an answer for you. Thought it might come out the toilet. I am so paranoid, I stand and watch it, pushing the gauge button every few seconds till it reads full. I usually have to flush it twice before it registers empty again. Stuff gets stuck on the sensors every time I camp.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 08-25-2016, 10:34 PM   #3
Interesting that it pushed to pipe out of the roof. I would research why it came out and where the contents went too.
Never multi-task when doing this task.
You can also monitor tank level by opening flush valve and looking down into tank.
Also never keep your black tank empty. The contents will bridge and get hard. Always keeps a few gallons in tank. If freezing is a concern dump some rv antifreeze into the tank.
mfMcFroggierPod is offline   Reply With Quote
Old 08-25-2016, 11:14 PM   #4
Hmmmm. The vent to the roof comes from the black tank, not the toilet. If it pushed up then it must not have been sealed to well to the black tank or the black tank expanded when full and the expansion pushed the pipe up.
You said pushed it back down. Did it seem like it just slid back down or did you have to exert some force? Did you see any evidence of of black water dripping under your RV? I bet your tank expanded due to water pressure and that expansion pushed the exhaust pipe up..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-26-2016, 05:45 AM   #5
ilmor's Avatar
You're very fortunate it came out outside!!
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-26-2016, 05:53 AM   #6
SeaDog's Avatar
On the plus side you found out your toilet has a good seal both at the floor and bowl. I think the vent may have pushed up some due to the tank expanding. Did the pipe lift the roof material or tear free? either way check the seal around the pipe at the roof.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 08-26-2016, 06:16 AM   #7
Life is great's Avatar
Wow, came out the vent on the roof.
Once I left mine on while i was cleaning up and I was keeping track of it until a friend came over and start chatting and then i forgot about it. I was standing next to my out door sink and I heard a bubbling sound and I stopped and had no idea what was happening but then the sink started filling up, OH NO and i take off running to shut off the water. The sink did over flow just a little bit, my outdoor sink is hoked to the black i found out then. Needless to say the outdoor kitchen got fully sanitized that go round of cleaning up. DW still nags me about that opps. I'm just glad it didn't come out on the inside somewhere.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - ??
Life is great is offline   Reply With Quote
Old 08-26-2016, 06:31 AM   #8
kc8lvy's Avatar
When I back flush I always start a timer on my phone for 5 minutes. Your time maybe different.
2004 Dodge Ram 2500HD Cummins
2013 Cedar Creek Silverback 33rl
kc8lvy is offline   Reply With Quote
Old 08-26-2016, 12:01 PM   #9
Thanks for all the replies it just popped the cap off the vent no major damage. I siliconed it back up. It did push back down very easily so I'm going with the theory that the tank expanded as well!!
Old 08-26-2016, 04:10 PM   #10
I would still try to inspect the vent pipe attach point if able at tank.
black, black tank, tank
