Old 05-09-2015, 05:58 PM   #11
As was said .. it is a "holding" tank. As a former boater (sail plus Great Loop on a cruiser) I only dumped my holding tank when it was getting full. Sometimes it would be weeks before I dumped it in hot weather, and as long as you kept the odor control chemicals in it, all would be fine. Can't think why my RV would be any different.
jmencel is offline   Reply With Quote
Old 05-09-2015, 08:16 PM   #12
mike.t's Avatar
During warm/hot weather i am sure the bottom of your boat is a lot cooler than the bottom of an RV.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-10-2015, 08:22 AM   #13
how does the black tank smell get into the living space ? if there is a water seal in the toilet and water in the sink and shower traps? thanks
Big Bill is offline   Reply With Quote
Old 05-10-2015, 09:56 AM   #14
mike.t's Avatar
Water seal? You mean the the seal that holds the water in the bowl? If the blank tank smells every time you flush it it would release an odor.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-10-2015, 10:24 AM   #15
That's only momentarily, I think he was saying it was constant which shouldn't be unless he was getting it from the outside vent blowing inside.
Old 05-10-2015, 10:38 AM   #16
mike.t's Avatar
Guess i didn't read all of it. If it is constant that is a problem.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-10-2015, 11:13 AM   #17
Witch Doctor's Avatar
Originally Posted by BMATT View Post
Alright, here is my conundrum...I use my RV pretty much every weekend, but generally not for anything extravagant - sometimes just to a friends house, sometimes just to cruise around, etc.
Problem is, I have no trailer parks or RV dump stations readily close by and therefore need to "store" waste in the black tank for a few weeks at a time.
Now when I say waste, it isn't much at all - generally just my woman and I, perhaps 1-4 uses a weekend. I make sure to dump a lot of water in and ensure that the toss in chemical pack is in there as well.
How long can I keep this up? Obviously if I have more people using it I would make the trek and empty, but this does not happen often.
Any help would be appreciated, thank you and Happy RV-ing.
I had the same problem in hot weather, Then I switched to a product called full timer from CW. The problem ended sometimes depending on heat I might put 8 oz's instead of the 4 that it calls for. Also if your bath fan is on when you flush it draw the smell out....
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-10-2015, 12:04 PM   #18
Left Coast
Originally Posted by savi18 View Post
Where do you guys dump your black waste, in NZ we have to locate dump stations to hook our hoses up, I suppose in the states it my be a few miles to find one,
In this area, rest stops have dump sites... some truck stops,for a small fee, also. Or, late at night, at your neighbors door step ( right coasters)
Old 05-10-2015, 12:11 PM   #19
B and B's Avatar
Your neighbours to the north would hang you up by a redwood for such thoughts! They protest someone using a jet ski on english bay for gosh sakes...
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-10-2015, 09:52 PM   #20
I drain at about 2 weeks. But when I had to redo my driveway for the concrete I dug a trench in the driveway and I put in power/sewer made a 15% drop in the sewer line and connected it to my main house sewer. But before that I used the Flying J which was 2 miles down the road.
outloud is offline   Reply With Quote
black, black tank, drain, tank
