Black tank fell
So.........fun stuff. I have a 2012 Crusader 35BHQQ. One of the black tanks somehow fell out of the angle iron brackets holding it up.
I cut the underbelly open, poked around til I figured out that one side angle iron is welded up, one is bolted. Removed the bolted bracket, removed the toilet from inside, unscrewed the water fitting and pulled it out of the floor. Figured ok, now i just slide it back in place and put the bracket back up, add some metal strapping so it doesnt happen again and done.
Well, there is about 1/4 inch of wiggle room i need that I cant get because of some fitting, guessing the vent pipe. I have plenty of wiggle room from the crapper connection. The vent pipe hole is cut tight to the pipe. I can't figure out where this vent may lead to.
Any help out there? Anyone dealt with this? I literally need 1/4 inch wiggle. I will be forever indebted for help.
