Old 08-12-2015, 10:35 AM   #31
CAT-RN's Avatar
Black tank flush ???
Post 20, 21, 22, 27, 30 I agree with the black tank is vented. No other way it can work. No way for black tank to get to the fresh water unless it runs on ground & into the well.
Russell
CAT-RN is online now   Reply With Quote
Old 08-12-2015, 11:03 AM   #32
TURBS's Avatar
Really not sure why people think these are closed systems?
Only reason the "leave" open sticker is on there is so when flushing you don't walk away and forget flush is on and water and "other" comes spilling out over the roof.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-12-2015, 11:08 AM   #33
CAT-RN's Avatar
TURBS
2011 32bhok Sabre
Exactly!! Maybe for warranty purpose?? Warranty against stupid! Can't fix that anyway !!
Russell
Old 08-12-2015, 11:10 AM   #34
The only way smell would exit from septic system is if you leave the black tank valve open, which you should not do.
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 08-12-2015, 03:16 PM   #35
Pockets
The only sticker I have on my TT is black tank flush. I'm going to a full service site this weekend. I'll take your word for it that the valve has to be opened first. But doesn't the black tank vent through the stink pipe?
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg
2015(36 nights) 2016(74 nights) 2017(174) 2018(105 nights)
Pockets is offline   Reply With Quote
Old 08-12-2015, 03:17 PM   #36
TURBS's Avatar
Yes it does
TURBS
2011 32bhok Sabre
Old 08-12-2015, 04:58 PM   #37
Ham Camper's Avatar
Well I guess this thing has sure been hashed about. I just could not see how anything bad could happen if my black tank drain was closed and I was running water into the black tank via the black tank clean hose connection. I mean I had the toilet open and I was watching the water rise into the black tank. It worked for me doing it this way and really got the black tank clean. I also used one of those hose connection wands that has the spinning head on it. That seemed to do a good job but some may not like doing that. I also see where someone said if you fill up the black tank with water maybe the jets are covered by water may not clean as well as if you left the drain open. That makes sense to me. Thanks everyone for all the input.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 08-12-2015, 05:21 PM   #38
Is this the end??
Im going camping!
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 08-12-2015, 08:25 PM   #39
Ham Camper's Avatar
Bluewoo.......go camping!!
2015 GMC Denali HD
Old 10-05-2015, 10:25 AM   #40
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
Is there some other step necessary to get the black tank flush to work?
I tried mine for the first time today.....and quickly found out that the quality control people at FR were sleeping on the job. I had water squirting all over the inside of my bathroom cabinet. The tank flush line comes through the wall from the outside inside the cabinet with a white flexible hose. The guys at the factory didn't tighten the fitting on what I'm assuming is the check valve, black plastic thing that the white hose goes in to and has a blue pex line coming out and running parallel to the white line before disappearing through the base of the cabinet to where the black tank is.
I tightened the connection on the incoming hose to what I'm assuming is the check valve, cleaned up all the spilled water and tried again.....nothing. No water went into the tank. I kept the toilet open so I could see - nothing. What else do I need to do?
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
black, black tank, black tank flush, tank
