Old 09-13-2014, 04:16 PM   #1
Black tank flush inop
We took a 10 day trip for our break-in run in our 2015 XLR 395 AMP. Upon dumping and cleaning the black tank, nothing happend?? I dumped all tanks, black and the two greys. All good so far, went to flush it and it seemed as though no water was flowing?? I verified the hose had water flowing, the black tank valve was open.
How does this system work? I pulled the wall out of the basement and saw it is all pex hose (verifying no kinks) Could the nozzle be clogged? I'm sure this will be a warranty item, just wondering if anyone has info on the system operation.
Thanks in advance
2015 XLR 395AMP
2011 Dodge Ram 3500
bggrndodge is offline   Reply With Quote
Old 09-13-2014, 04:32 PM   #2
Mine had the check valve installed backwards. Follow the flush line to the check valve and look for the arrow on the fitting and reverse if needed.
Jmw1 is offline   Reply With Quote
Old 09-13-2014, 04:36 PM   #3
Is the check valve the little red piece right after the fitting you attach the hose to? I noticed it, but didn't realize it was a check valve, now I'll go look for an arrow. Thanks!!
2015 XLR 395AMP
2011 Dodge Ram 3500
Old 09-16-2014, 10:02 PM   #4
Never mind I found it, it was under my bathroom sink. Flipped it around and will try again! Thanks!
2015 XLR 395AMP
2011 Dodge Ram 3500
black, black tank, black tank flush, tank
