Old 06-03-2015, 08:49 AM   #11
Originally Posted by bubbles View Post
The tank is vented and the rinse out tubing is 3 or more feet above the tank. Mine is 5 feet. The input to the tank is at the top of the tank. What you suggest can't happen.
OK so the Factories just put the Valve in for ? Youroo!!
Old 06-03-2015, 08:50 AM   #12
Originally Posted by jeff64 View Post
...The vacuum break mod not necessary IMHO
It's not a mod, just take the worthless , totally useless pc of junk out. The only good thing about them is it's a good place to have a leak, which they do quite often.
Mine leaked from the time it was new and luckily it was a seep that leaked down the hose directly to the ground and never soaked anything. Finally found the leak about a month ago.
Old 06-03-2015, 09:45 AM   #13
Not a hydraulics expert, but my thinking- and the way I've flushed the black tank in the past is-
1. Drain black tank
2. Close main valve
3. Connect water hose to black tank connection
4. Fill tank to 3/4 full
5. Drain black tank with water on
6. Repeat steps 4 and 5 ~ 3X
7. Turn off water
8. Check level indicator with tank empty. If reading is empty, go to step 9. If not, repeat steps 4-8.
9. Disconnect water hose AT THE CAMPER.
Step 9 is the reason I don't feel the need for the vacuum breaker. If I break the connection at the side of the camper and NOT at the hydrant I see no way possible for it to siphon water back out of the black tank. As a matter of fact, the only way I can foresee it being able to siphon back out is if you have the tank full when you disconnect AND you disconnect at the hydrant first instead of at the camper. I suppose that possible scenario is the reason for the vacuum breaker???
Old 06-03-2015, 09:48 AM   #14
Originally Posted by Indymule View Post
The vacuum breaker is on the black tank flush to allow the line to drain when the pressure is off. The recommendation to only use the flush when the drain valve is open is because if you leave the flush on and the tank fills, it is going to go somewhere. If it can't go up the toilet, then it will go up the vent pipe and provide a nice #$%^ shower for your trailer.
I fully understand the reason not to have the dump valve closed when using the flush. You'd have a moment on the way if not!!! Just wanting to make sure that the "fullway termination valve" WAS the dump valve. I assumed it was, but it's better to be safe than sorry, right.
Old 06-03-2015, 10:13 AM   #15
bubbles's Avatar
1. Drain black tank
2. Close main valve
7. Turn off water
The only thing I do different is connect the rinse out and turn it on first and then dump and then close main valve till tank is full (monitor indicator and cross check through toilet) and then dump again then close main valve and let a couple gallons enter tank through rinser before shutting down. There is residual water that comes back out the hose when disconnecting but it is not from the tank, just water in the input side tubing to the backflow preventer. Never have indicator issues with stock sensors giving false readings. I use a "Y" that has separate shut off valves at the water source faucet so I don't have to shut water off to the coach for dumping purposes. it must be noted that these stock rinse out systems do not fill a tank in a split second. Mine takes about 20 minutes to fill. It's not a gusher. I'm done.
Old 06-03-2015, 11:50 AM   #16
I recently was rinsing our black water tank and a neighbor camper came over to ask a ?'n...Went off with him.....Heard the BH holler.....Water came up thru toilet on BRm floor..A mess!!!!!!!!! just stinky water as I had rinsed just a few mins previous........Would like to install a water timer on hose to shut off after a few minutes......This will not happen again!!!!!!!!!!!!!! J
Jim in Halifax is online now   Reply With Quote
Old 06-03-2015, 12:04 PM   #17
What I posted is for (ANY RV) they are Not all Plumbed like Yours! YES it can Happen,that is why the Fac.put them in and ALL of the other Sewer Aids ( Sewer Solution/Flush King/Flow Jet) ALL come with a Backflow Preventer! They have No way of knowing how the Application in which it will be used! Youroo!!
Old 06-03-2015, 12:16 PM   #18
Hi,
I added a simple, cheap in-line valve right at the female fitting that takes the flush hose. Close that valve before shutting off the water at the faucet, and there will be no back-flow.
FWIW.
Rich Phillips
richp is offline   Reply With Quote
Old 06-03-2015, 01:04 PM   #19
bubbles's Avatar
Sorry, thought this was a Forest River Forum utilizing their black tank system clean out installs. No specifics in your post to the contrary.
Old 06-03-2015, 01:13 PM   #20
That's OK F/R makes lots of RVs and they are Plumbed different! Youroo!!
black, black tank, black tank flush, tank
