Old 06-03-2015, 07:51 AM   #1
Black tank flush question
OK- stupid question...... This warning (2nd pic) is referring to the main dump valve, right? My last Puma, a 2015 also, did not have this warning sticker and I want to make sure I'm not missing something here! Also, it appears as though I have a vacuum breaker installed on this one(1st pic)- which a lot of members have had issues with, I think. Anyone remove this and just connect the lines? I see absolutely no reason for a vacuum breaker on a tank with a vent, but????
Name:	File Jun 03, 7 31 57 AM.jpg
ID:	78919   Click image for larger version
Name:	File Jun 03, 7 33 13 AM.jpg
dustman_stx is online now   Reply With Quote
Old 06-03-2015, 07:57 AM   #2
Indymule's Avatar
The vacuum breaker is on the black tank flush to allow the line to drain when the pressure is off. The recommendation to only use the flush when the drain valve is open is because if you leave the flush on and the tank fills, it is going to go somewhere. If it can't go up the toilet, then it will go up the vent pipe and provide a nice #$%^ shower for your trailer.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 06-03-2015, 08:02 AM   #3
Decal is SOP some are not applied. Yep that Valve will/could Fail,BIG water Mess to clean up! If you connect the hoses just use a Outside V-breaker! Youroo!!
Old 06-03-2015, 08:03 AM   #4
Yes, I removed mine and cut out about 8' of hose and connected the inlet hose directly to the hose going to the tank. I also have a factory installed backflow valve behind the outside hose inlet.
Old 06-03-2015, 08:13 AM   #5
Thanks all!!!!
Old 06-03-2015, 08:23 AM   #6
jeff64's Avatar
For the life of me, I can't see this as any more than a tank rinser. If you have a clog or restriction going out of the tank into the pipe, no way in heck are you going to build enough pressure to move it through. I still use the flush king at least one time then the rinser does it's job OK. The vacuum break mod not necessary IMHO
Old 06-03-2015, 08:37 AM   #7
If your the Next person to hook up the Hydrant that has been (Backfed?) from a hose that was filled with (SEWER WATER) you would want one! Youroo!!
Old 06-03-2015, 08:38 AM   #8
bubbles's Avatar
Yes and the proper way to rinse is to close the outlet valve, fill the tank, open the outlet valve till emptied and it's a done deal. Just don't walk away while performing this procedure. Complete the rinsing of the black tank before moving on to something else. Use the indicators or look down the toilet to know when tank is full. You will never have an indicator issue due to something hanging up on the sensors.
Old 06-03-2015, 08:44 AM   #9
bubbles's Avatar
The tank is vented and the rinse out tubing is 3 or more feet above the tank. Mine is 5 feet. The input to the tank is at the top of the tank. What you suggest can't happen.
Old 06-03-2015, 08:49 AM   #10
Mr. Dan's Avatar
I don't know of anyone who thinks of this as more than a tank rinser.
You're right in your assumption that its purpose is NOT to force large blockages out of the black tank system.
If your vacuum breaker failed and blew water all inside your trailer, would you consider it necessary to remove or replace it?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 7; booked = 22
black, black tank, black tank flush, tank
