Old 09-01-2014, 10:45 PM   #1
bea60's Avatar
Black tank flushing issues
I recently purchased a 2015 2604WS Rockwood. I see that the black tank has the power washers built right into the tank so that it makes it easier to flush the tank out. What I did notice is that one if those turbo jets is located directly at the base of my toilet. Meaning anything that is flushed gets stuck there. No matter how many times I clean it out, it never fully gets cleaned and some times (which already has happened twice, it gets clogged real bad if I have guests) backs up. No matter how much chemicals I have thrown in, and I have also allowed the black tank to almost fill up. The clog does not break up. I have had to use a wire clothes hanger to work it apart. Let me tell you........I am not going to be a happy camper if I have to continue to do it that way. I worry if my guests asks to use the bathroom for that reason. Not everyone realizes that these toilets do not work like the ones at home. In my opinion I feel that the turbo jet is in a very very bad spot. I am at a point that I want forest river to replace my tank. I think someone goofed while assembling the black tank prior to installing it in the camper. So with that said, does any one else have this issue. Any feed back is appreciated. My 2014 2304S had the same system, and I never ever had any issues. Thanks to all.
2015 Rockwood 2604WS
2008 Toyota Tundra CrewCab Limited
bea60 is offline   Reply With Quote
Old 09-02-2014, 01:08 PM   #2
Explorer
Nope doesn’t sound right and it would bug me too.
I have heard about these systems but have never had one and am not sure how they are installed. If it is in the side of the tank, can a coupling be added moving the system several inches.
Sounds like a warranty issue.
While the orientation of the jet may not be in a good location, by closing that one jet off the other jets are working at a higher pressure, cleaning better.
Ya sorry I don’t know.
Good luck
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 09-02-2014, 01:14 PM   #3
bea60's Avatar
Looks like these jets are installed thru the plastic tank from the outside in and glued, lots of glue. You can see the think heavy mustardy color glue around the jet and where it leaked from the istallation. The under belly of my camper is totally enclosed, so it makes it difficult to see anything from the upside. Thanks for your ideas, it's well appreciated.
Old 09-02-2014, 01:17 PM   #4
vinmaker's Avatar
Sorry to hear that. I am totally new to the whole black tank issue myself as I have never owned a pop up with one before. The new one has a black tank.
I am wondering if you can remove that particular turbo flush and then just patch the hole with some epoxy resin or something. You definitely want that taken out. From what I understand about the systems. They are glorified outhouses. You need a straight shot down the hole. It is not like a house. it is more like a porta-potti or an outhouse.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
black, black tank, black tank flush, tank
