Old 04-05-2011, 10:42 AM   #1
cmhbob's Avatar
Black tank help needed
Our black tank seems full and the bowl will not empty, but when we pull the valve to dump, there is just a little trickle, then it stops. Any ideas?
Bob Mueller | Fulltiming family of 9 since Feb 2011
More About Me
cmhbob is offline   Reply With Quote
Old 04-05-2011, 11:02 AM   #2
BigDTx's Avatar
The valve my not be opening are you sure it is opened? have you tried to run an old piece of hose or a stick up into the dump outlet to see if the valve is opening. If it is then you have a problem with to much solids in the tank. When was the last time you were able to dump it? have the contents been in there for a long time (over winter)? Have you tried a bottle of RV DIGEST-IT? use the entire bottle and let it set for 24 hours like the label says.
We need more information.
BigDTx is offline   Reply With Quote
Old 04-05-2011, 11:04 AM   #3
BigDTx's Avatar
I see you are a full timer. is the TT set up at a permanent location? If so have you left the dump valve open for a long period of time?
Old 04-05-2011, 11:32 AM   #4
camper_Lucy's Avatar
Besides the above, are you sure you are opening the correct valve? Most TT have the Gray and Black water coming out a common pipe (separate valve) but some have them completely separate also. Just a sanity check.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 04-05-2011, 12:27 PM   #5
BigDTx's Avatar
Good Question!
Old 04-05-2011, 02:47 PM   #6
Herk7769's Avatar
I am thinking you have a real "sticky" problem. I am guessing your valve body is packed with poo. There is not enough water pressure to push through it.
To fix this problem:
1) STOP USING IT. This will only make the problem worse.
2) If the black water is already backing up into the bowl, the tank is already chock full you are kinda hosed. There is no way to add RV-Digester to your black tank.
3) Call a RV plumber and get ready for a big bill. RV tank guys hate/love this scenario. They hate it for the mess, but love it for the big bucks.
Now if calling out the troops is out of the question;
Open all windows and clothes pin your nose.
Wear clothes you intend to burn.
Wear rubber gloves and goggles.
Turn off water to the toilette so you can open the bottom valve without adding additional water to the tank.
Open the black dump valve to the sewer (use a clear elbow if you can and have someone watch for "movement"
Take a flexible water hose about 6 foot long and start pushing it through the toilette and pull it up and repeat while twisting it around (you are trying to find the open valve that is blocked with solids).
Hopefully the blockage will be opened up enough to let some of the water out of the tank.
Once the water starts to leave (and hopefully some solids too) close the valve. Add a FULL quart of RV-Digester or similar biological sewage digestion treatment and let stand for 24 hours. (Says 12 on the bottle but more is better).
Open the black dump valve and lots more should come out.
Dump till empty.
Close valve and fill black tank with water. Add ANOTHER quart of RV-Digester and let stand 24 hours.
Dump again and flush well with Turbo wand or Turboflush until water is clear running.
Throw away (or burn) clothes, hose, gloves, and goggles.
Follow correct dumping instructions in the future.
HAM CALLSIGN - KC3FFW
Old 04-05-2011, 02:58 PM   #7
I have had this happen to me and is why I own a Flush King. Stuff accumulates at the bottom of the tank and can block drainage. A FK is cheap insurance against this happening again. Find a way to back-flush the tank, you'll be surprised what comes out.
ctdrules is offline   Reply With Quote
Old 04-05-2011, 03:01 PM   #8
MtnGuy's Avatar
A Flush King might work good in this situation.
Old 04-05-2011, 03:11 PM   #9
BigDTx's Avatar
http://www.forestriverforums.com/for...rain-7821.html
The above link is for a thread on my previous problem, you might find some help there.
If all else fails you will need to call out someone like I had to do when we first brought our TT home, the black tank was full and a poop cake had formed. I used All Pro Water Flow All Pro Water Flow I think I paid about 200.00 to have all tanks flushed and sanitized and I paid a little extra to have the hot water heater flushed also.
Old 04-05-2011, 03:33 PM   #10
Herk7769's Avatar
Maybe if you started out with low water pressure it might do the trick over time, but I would try clearing it from the top first. IMO
I am thinking if you blasted the water in under pressure it might push the black water up the stack if it broke free.
black tank
