Old 06-15-2011, 08:44 AM   #21
Herk7769's Avatar
A picture is worth a thousand words
Although that has never stopped me before!
The yellow wire is 1/3 full
The Green wire is 2/3 full
The Red wire is full
As you can see, one good flush or two will turn on the 1/3 light.
the 2/3 light is about half full
The FULL light is about 7/8 full
NEVER dump below 2/3 and try to always dump with the full light on.
If below 2/3 light run the flush water until the full light comes on; then dump.
Name:	Black tank 2.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-15-2011, 08:51 AM   #22
MtnGuy's Avatar
Originally Posted by Labzy View Post
Hmmm...... how to ask this tactfully???
Do you still 'use' it when it is like that?
Anther yes here.
Old 06-15-2011, 09:36 AM   #23
(Kim)
Labzy's Avatar
Ok....I will live dangerously next trip and heed your words.
(hope you understood my meaning of the word 'use' in that sentence
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 06-15-2011, 11:42 AM   #24
MtnGuy's Avatar
I am pretty sure that I got your drift.
Old 06-15-2011, 11:50 AM   #25
(Kim)
Labzy's Avatar
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 06-15-2011, 02:14 PM   #26
Villa Estate 392FLFB
The_Stuff's Avatar
so very true. i had to tell that to the GF. she kept dumping it when it started to stink... now i gotta get the levels up and dump over and over again to get the "crap" flowing out.
another good tip. when its "finished" dumping, dump another 5 gallons down the toilet to get more solids and paper to come. if nothing comes dont dump any more down or you might wash it out too well and the bacteria colony will become weak.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 06-15-2011, 03:08 PM   #27
Herk7769's Avatar
Originally Posted by The_Stuff View Post
another good tip. when its "finished" dumping, dump another 5 gallons down the toilet to get more solids and paper to come. if nothing comes don't dump any more down or you might wash it out too well and the bacteria colony will become weak.
Not a big fan of the "bacteria colony" group. I sanitize my septic system with bleach each season and flush and turbo regularly. While I know it is not possible, I would like to keep my gray and Black tanks as squeaky as the fresh tank.
Old 06-23-2011, 12:57 PM   #28
jim44646's Avatar
I just pulled my black water sensors today. The sealing grommet was mushroomed and the the sensor was kind of recessed into the center. The resrssed area was full of hardened "crap". I have tried bags of ice, Calgon, Flushing wands. nothing really helped. I replaced them with Horst sensors. Hope that works
jim44646 is offline   Reply With Quote
Old 06-23-2011, 02:56 PM   #29
Herk7769's Avatar
The sensor "cap" should have been even with the rubber grommet. If it was "inside" the rubber, it was overtorqued when was installed.
The rubber sleeve is supposed to "crush" and seal the hole when installed. You did notice that the black tank probe "shield" went on top, right? The gray tank probes do not have TP shields.
Name:	Horst Probe Install 035.jpg
ID:	6485   Click image for larger version
ID:	6486   Click image for larger version
Name:	Horst Probe Install 044.jpg
Old 06-23-2011, 07:43 PM   #30
jim44646's Avatar
The trailer is a 99 Jayco. I bought a few years ago, sensors never did work right that's why I changed them. I don't know if it came from factory or someome removed them to clean but they were really torqued. The sensor was embedded into the rubber. The rubber was so flaired on the inside of tank that the flaired part tore partway off. I guess I'm anal. I can look down the toilet to see how full the tank is. And yes I did install new ones with hood on top. Changing gray water while I'm at it.
Old 07-10-2011, 06:59 PM   #31
jim44646's Avatar
So much for the great horst black water probes. Installed probes and every thing read 0. After one week of camping I dumped black water tank. After rinsing twice I checked monitor again only to discover it read 1/3. I rinsed again and checked monitor and still 1/3. I just wasted time and money replacing old probes with Horst probes.
Old 07-10-2011, 07:18 PM   #32
Herk7769's Avatar
Jim,
I am really sorry your experience with them was not as good as mine (so far).
Some things to check (assuming you want to drop your belly pan again) is the lowest probe being oriented correctly. I almost rotated mine out of alignment when I tightened up the wire nut. I wear bifocals and of course the focal length at arm's length sucks. I can read and drive fine, but shooting a rifle or working over my head with tools is a challenge. Trying to fine focus at that distance is darn near impossible.
The only way for that probe to be "on" is for there to be an electrical connection between the probe wire and the ground probe. If you are not getting a complete dump for any reason the "1/3" probe will be under water. Since the ground and the "on" probe are at the same level in the tank, it won't take much to turn it on legitimately. The dump valve is not at the very bottom either. Some water will always be in the tank unless you let it dry out with the valve open.
In my camper, one #1 flush will turn on that light.
It is really a "Not Empty" light.
As you can see from the picture of the tank, it will not take much sludge in the bottom of the tank to keep that light on. Maybe an RV-Digest-it treatment for 24-48 hours might be in order.
Name:	Horst Probe Install 012.jpg
black tank
