Old 10-04-2014, 01:40 PM   #1
gbpacker's Avatar
Black Tank Lubricant
The dump valve on my black water tank is difficult to open and close. What would be the proper lubricant to free up the valve without affecting the seals?
gbpacker is offline   Reply With Quote
Old 10-04-2014, 01:55 PM   #2
Ford Idaho's Avatar
Some type of cable lube will do as long as you can work out a way to apply it the full length.
Did it just become hard or has it been over time?
Old 10-04-2014, 02:13 PM   #3
B and B's Avatar
I used some inexpensive vegetable oil. Make sure tank is empty, use a litre and work the valve to lube the seals.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-04-2014, 02:53 PM   #4
Campin Cajun's Avatar
Has it always been difficult? If not it may be damaged, might not be a bad idea to buy a spare to keep on hand just in case.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-04-2014, 03:02 PM   #5
Ford Idaho's Avatar
There was a thread here awhile back where someone found the cable and housing kinked from a bad install causing it to bind up.
While a spare is a good idea the cause needs to be looked into and corrected.
Old 10-05-2014, 08:37 AM   #6
jevanb's Avatar
Mine had to be replaced after the first time I used it you would think the factory would try it before it left
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 10-05-2014, 08:48 AM   #7
Ford Idaho's Avatar
And the dealer should have tried it while getting it ready for the PDI.
Old 10-05-2014, 09:50 AM   #8
Rugged Brown's Avatar
My grey tank valve is very hard to pull and it's been like it since day one. When I did my rerouting sewer modification, I took the thing apart, greased it up with some silicone grease and it worked easy peezy, on my work bench. When I put it back in place, tightened the 4 nuts, back to the original , hard to pull operation again. I just use both hands to pull that valve. In time, the handle will break. perhaps I should have a replacement on hand. Defer to next spring. Out of site, out of mind.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-05-2014, 10:22 AM   #9
Witch Doctor's Avatar
CW sells a product that you dump in your empty tank and let it set for 4 hrs or so if I remember. I had a hard time pulling mine open after I used it no problem like before. It is also a protection for your seals. I used it in all 3 tanks. I think I used a quart.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 10-05-2014, 11:10 AM   #10
I've been told you can use peanut oil also. Never tried it, but the TST stuff is just coconut oil.
black, black tank, tank
