Old 04-20-2015, 12:32 AM   #11
Sounds like it won't help you at this point unless you end up buying a new tank but for future reference, on my Salem there is no glue where the pipe enters the tank. There is only the grey putty like you would seal a window with and it does not leak.
J W Bowman is offline   Reply With Quote
Old 04-30-2015, 08:29 PM   #12
Commercial Member
Slow going. Weather has not cooperated and some other projects had to get done. BUT am about ready to use special $$ 3M adhesive on the Poly tank to attach some ABS that I can then glue standard fittings to.
I am still interested in a backup plan which would probably mean a new tank. The problem is Camping World says that there are no replacement tanks available and aren't even any drawings or supplier info available. Their only suggestion was to order a custom tank which would take 4 to 6 weeks. Sounds like they just aren't interested.
I note that there are a number of smaller 21' to 24' Class-C with identical bathroom layout and similar size tanks (22 to 25 gal)
What I can't find out is who makes tanks for Forest River, Thor, Jayco or 4 Winds.
I can't believe that none of these companies are not making RVs right now.
Any ideas
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
black, black tank, tank
