07-10-2015, 05:04 PM
Black tank prep
Hello
We are fairly new to the black and gray tank world. This is our second season with our Flagstaff Microlite 25DS.
I think my hubby and I have a system going with the dumping at the end of our trip. However, I have been researching more on this procedure.
I have some questions.
We basically camp 5-6 times a season being from summer to early fall.
We camp mostly state parks with no water or sewage hook up so it is to the dump station we go at the end to empty (and also before to fill up the fresh water tank).
We mostly camp 2-3 day weekends with an occasional 4-5 day jaunt.
When we dump at the end of our weekend, we may not go again for 2-3 weeks.
We pour the black tank additive after we are set up into the toilet/tank along with some water to cover the bottom of the tank.
When we empty the black tank at the end, it can show 2/3 full or so. My question is, are we to leave some small amount of water AND additive in the tank after our trip or is this not necessary? I see from some research I have been doing, that water should be left in the tank along with additive? If so, how much? What about the gray tank? We try to empty until the sensors are showing empty ( I know this can be unreliable) Thanks much for your input.
07-10-2015, 05:47 PM
YES, definitely add some water.
A black tank should NEVER be left dry for very long.
After dumping, I add 3-5 gallons of water from a bucket and then the additive.
07-10-2015, 06:35 PM
And use the GEO method while you're in camp:
Forest River Forums - Downloads - Geo Method
2011 Traverse LT, 3.6L, FWD
07-10-2015, 07:16 PM
GOOD stuff Rockfordroo! Thanks!
07-10-2015, 08:26 PM
thanks for the info.
So, after I dump the black tank and gray tank, then I should add an additional 3-5 gallons with the 4 oz of liquid chemical?
So when I return to camping in say 2-3 weeks, I am good to go without adding anything else?
also, it is ok to leave the gray tank empty then?
07-10-2015, 08:57 PM
PT - the black tank is the one that needs special "care" as detailed above. So yes, put 3-5 gallons of water and what ever chemical or GEO method additives you choose. The gray tank only handles soapy water so it will be fine if left empty. Some people put a little water in the gray tank too on the theory that it prevents odors. I leave mine empty.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
07-10-2015, 10:17 PM
PT Lady,also treat the Gray tank same as Black! Your kitchen sink as well as your body oils will Stink up the Gray tank just like the Black! Youroo!!
07-10-2015, 10:54 PM
I do the water & chemicals when leaving the CG and do the GEO when I arrive.
07-11-2015, 07:00 AM
Ice cubes
After we dump our black tank, Just before we get ready to pull out and hit the road, we flush all our ice cubes down the toilet, These will slosh around and clean the sides and bottom of the tank, and then they melt and go away.
we don't use any additives
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
07-11-2015, 07:21 AM
I use the GEO method in both grey and black before I hit the road so that the softener/detergent sloshes around the tanks. When I leave the campground I dump, and then put a gallon of water and deodorizer powder in the black so that it sits in the tank while parked.
2012 Surveyor SP280
2017 Ford F-250, 6.7L Powerstroke
Equal-i-zer
07-11-2015, 08:36 AM
My 2 cents...
I see most replies like to leave some water and additives in the black tank when the rig is not being used.
I always use the GEO Method...
I think this is probably a 'personal preference' ...to leave tanks wet or to leave tanks dry...as I like to have the tank 'CLEAN' and Dry when not in use.
Doing so means that my last flush of the tanks is very thorough by seeing only 'clear' water (via clear elbow) coming from the tanks and using the tanks internal spray / rinse.
IMO....It all depends on how soon you are going to use your rig again.
If it is next weekend...then sure... leaving water etc. in the tanks would be fine.
However, if it is going to be several weeks or months all that water is more than likely going to evaporate via the vent stacks leaving any chemicals to dry out and crust up inside the tanks. (with exception to rigs covered or inside buildings, vent stacks won't have the wind blowing over the stack)
I'm not saying that what I do is right or wrong..... I leave that up to my wife
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~ Trail Air - Tri Glide Pin Box 2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles Edge programmer, 4" SS exhaust turbo/back, Tru-Cool Max Trans Cooler, Bilstein Shocks Vancouver Island, B.C., Canada
08-15-2015, 10:13 AM
I have used the GEO method for my black tank & it seems to work OK. My question now is , has anyone put liquid fabric softener in black tank & what were the results? I know if you do that to baked on stuff on your baking pans, it will completely loosen all residue & just thought it might do the same on black tank. Always looking for an easier way to clean my tanks.
08-15-2015, 10:18 AM
I started doing that two trips ago, hoping to get the black tank sensors to show correct fill level, no help yet, but who knows...if it works, I'll pass it on.
2015 36DBK5
2015 Chevy 3500 dually
08-15-2015, 11:30 AM
First of all.... Congrats on using the Geo Method .
You will find it will prove to be very effective and economical.
I have used the Geo Method for years, on several different rv's.
Solved problems like - odors , clogged sensors - removed scum on sides of tanks, and more.
The Method's main ingredients are Laundry detergent (powdered) and
water softener (powdered) FYI... I buy the cheapest laundry soap and use the water softener sparingly, as I find it does not have to be used too it's fullest every time.
IMO.... The laundry soap provides the fragrance and cleaning where as the softener provides a slippery film that adheres to the tank sides, both are powder which break down over time.
There have been some using a 'liquid' softener and I do believe have had some good success with it.
Your Question: " has anyone put liquid fabric softener in black tank & what were the results?"
My reply:
It does sound like it may have the same results....However, I personally have not tried it 'yet'....but I just may do so.
In closing:
The whole thing about 'holding tanks' they are just that...and never are meant to be 'septic tanks'..as all those Expensive RV chemical pushers would lead you to believe. ...IMO... I do not believe that 'any' of those chemicals " break-down" the solids in a 3 or 4 day period...waste of money!
Hope this helps
Islander
08-15-2015, 11:43 AM
Ninemmsig........
Just a quick tip:
For the best results ..I have to 'help unclog the sensors' is to put your solution (soap and softener) into your "dumped empty tanks".. put in at least 3 to 4 pails of water (in each tank) before you leave to the next site (or home) ...the sloshing on the road trip will agitate in the tank and work it's magic.
If you are just going to another site...you are ready for action..... if you are going home and laid up for a while...try to keep the tanks good and wet until you head out...unless it is going to freeze...then drain.
Hope this helps
Islander
08-15-2015, 11:52 AM
Been using liquid detergent & water softener; haven't tried the powdered, but will. Also in my area you can't always find water softener. That is why I was wondering about the fabric softener. I know dryer sheets work good on baked on residue in baking pans, & on bugs on vehicles, etc., so it was just a thought that regular fabric softener would do the same in black & gray tanks.
08-15-2015, 11:54 AM
I always use the liquid softener, mainly because I can never find the powder. I've been happy with the results. But I also restrict toilet use to "number 1" only. Any more than that and its off to the bath house!
2012 Surveyor SP280
Equal-i-zer
08-15-2015, 12:00 PM
ptt87
That should work really good, unless it's raining. We put no paper in ours. A little inconvenient, but we're used to it now & it works for us.
08-15-2015, 12:31 PM
Canadian Full Timer
I love the Geo Method but find it is rather expensive, so am rotating month by month with the ZymeOut (no formadehyde in it) - we did use the Geo Method for two months but the readings are still not correct on the monitor, so something is still stuck there I think. We live full time in our fifth wheel so it does not travel anywhere and that, I know, would make a difference as it cannot "shake" any particles loose in the tank. (When the washing machine shakes, I always like to think that it helps with that
