Old 03-31-2014, 10:00 PM   #1
rburns4147's Avatar
Black Tank Question
We took delivery on a 2014 Rockwood 5th wheel a couple of weeks ago. We are very happy with the dealer, but the PDI wasn't the best ever. It was maybe a bit our fault as we told the guy that this was our fourth RV and he must have assumed that we knew everything about RVs, but we don't.
Our old TT did not have a black tank flush and this one does. On the outside of the unit is a connector for a water hose. What is the best way to use the flushing system and what is inside the black tank to make it work?
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 03-31-2014, 10:25 PM   #2
SKnight's Avatar
There's a spray nozzle inside the tank that basically pressure rinses the tank out. My dealer told me to dump the tank, leave the valve open and flush it for about 15 minutes. Didn't say how often, I figured I'd so it once or twice a year. Maybe every time I'm at a park with a sewer connection.
Old 03-31-2014, 10:38 PM   #3
papap's Avatar
Try to use mine before leaving campground.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 03-31-2014, 10:41 PM   #4
Dave_Monica's Avatar
I use it every time the black tank is dumped. I also connect a clear elbow (a Flush King) and run the black tank rinser until the discharge is clear. I've also attached a brass adapter to the outside shower with an additional back-flow preventer and flushed using the FW tank and water pump as many dump stations don't have a hose attachment to use for flushing.
Dave
Old 03-31-2014, 10:45 PM   #5
Kaadk's Avatar
I run mine every time I've got sewer hookups. I do mine this way:
1) dump black.
2) run flush until water generally clear.
3) close black valve, continue to run flush (fills black tank with clean water)
4) dump grey, wait for it to finish.
5) by now black should have about 1/4-1/3 full.
6) close grey, open black.
Repeat steps 3 and 6 waiting 5-10 minutes between dumps until I no longer see any "stuff" coming from the tank.
At the end of the season, I spent about 2-3 hours filling and dumping the tank getting it good and clean before breaking my final camp.
Old 03-31-2014, 10:47 PM   #6
Kaadk's Avatar
Dave
That's not a bad idea. Got details?
Old 04-01-2014, 12:15 AM   #7
RV
thrilskr123's Avatar
Black Tank Question
I do the same thing as Dave. I flush the black after every dump. When the water starts flowing 'clear', you should be good. I have one tip for you though, a lot of dump stations I've been to don't have a male hose end, just a cut hose. I bought a few 'male' hose repair ends and keep them with my tool kit. Since you have to have a male hose end to screw into your 'sani-flush' line, just push it on the hose end, tighten and your set, i got some at my local wallyworld for a few bucks apiece. Attached a pic.
Happy Camping
Dan
06 Sierra Sport F37SP TH
12 Chevy 1T Dually
B&W Turnoverball GN
B&W 18K Companion
Name:	ImageUploadedByForest River Forums1396329270.659545.jpg
'Life's too short to drink cheap beer'
06' Sierra Sport F37SP
12' Chevy 4X4 LB CC 1T Dually
B&W Companion 20K
thrilskr123 is offline   Reply With Quote
black, black tank, tank
