Old 10-20-2013, 09:53 PM   #1
dsagal79's Avatar
Send a message via Skype™ to dsagal79
Black tank scrubber leaks
I have a Rockwood 8311S and when packing up this last trip part of my routine is to hook the city water hose up to my tank scrubber. When using I this time I heard the wife yell about water spraying into the inside of the trailer near the water pump.
Checked it out and saw where it was leaking from. Can't tell what type of coupling it is but but I would like to fix myself. Anyone have this issue before?
My rig is also under warranty but I don't care for the local RV shop so warranty work is difficult. I purchased it 500 miles away from home. If I have to go the warranty route, can anyone recommend a good shop near western Maryland?
dsagal79 is offline   Reply With Quote
Old 10-20-2013, 10:14 PM   #2
Could the coupling possibly just be loose?
Old 10-20-2013, 10:17 PM   #3
tomjsas's Avatar
On my old trailer the anti siphon part of the black flush connection cracked and did someting similar. Had dealer fix it and said they had seen a couple fail back then. Quality issue. Could be similar on yours.
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 10-20-2013, 11:21 PM   #4
Denver, CO
garbonz's Avatar
If it's by the water pump and not up in a cabinet, its probably a loose fitting, either PEX or vinyl. You need to find out exactly where the leak is and you may just be able to fix it. If it's PEX you will need to go get a crimping tool and some bands (Home Depot) at the very least if you want to DIY.
If it is in a cabinet, then it could be the vacuum breaker which you can pick up a replacement and just screw in the lines and replace it.
2017 Fuse 23T
Old 10-21-2013, 12:39 AM   #5
I had the same issue happen to me this season.
My problem was a ball valve under my sink (probably the vacuum breaker/check valve thingy) was stuck open.
I was able to take the valve assembly off the PEX lines and open it up and free the ball/spring assembly.
I think that if there is too high of water pressure when you attach the hose to your black tank flush system, these cheap plastic valves maybe having problems getting stuck open.
Maybe the use of a water pressure regulator is in order.
sleepdude is offline   Reply With Quote
Old 10-21-2013, 12:48 AM   #6
NHFire 152's Avatar
Kind of off topic a bit; is it really a good idea to use your fresh water hose for your black tank flush?!
I have bad thoughts of seepage from the black tank back to the hose connection. Then you disconnect, put your fresh water supply hose away until the next trip. Yuck!
I have a totally separate water hose just for my black tank flush. It's painted orange on both ends as a reminder.
NHFire 152 is offline   Reply With Quote
Old 10-21-2013, 03:49 AM   #7
Most of the time this is the (Leak)! Replace with a Better valve,your discretion. Youroo!!
Old 10-21-2013, 08:16 AM   #8
dsagal79's Avatar
That looks like the defective part!!! Th other problem is that it is way up inside the cabinet. I am going to call my dealer and see I get will ship parts for me to do the repair!
Thanks all!
Old 02-19-2014, 03:04 PM   #9
Rsharrer's Avatar
Same problem in my Rockwood 8289ws. The sewer tank flusher line leaks intermittently. The line runs up into the wall and behind our shower. I can see the line goes to a black plastic part ( anti siphon valve?) and then back out. This is where the water drips from. Without removing the shower stall, this valve is not accessible. Can I bypass this valve? relocate it at a lower location?
Rsharrer is offline   Reply With Quote
