Old 06-19-2014, 04:52 PM   #1
Black tank smell
We have a 2013 Grey Wolf 26bh. We have noticed that when we open the lid to the toilet there is stench from the black tank. I'm assuming this is due to the gas from the black tank. Is this common or is the vent for the tank most likely blocked? I have not had a chance to get on the roof and check. The temperature here has been in the 90's consistently during the day and I have added more toilet treatment as the directions stated to do while using the black tank in temperatures over 85 degrees. It has not helped at all.
Grey9712 is offline   Reply With Quote
Old 06-19-2014, 05:19 PM   #2
Ford Idaho's Avatar
Did you add any water when you put in the extra treatment?
Are you using it or is it parked and empty?
Old 06-19-2014, 05:22 PM   #3
markb5900's Avatar
Have you put in the black tank "treatments"?
If not, it will smell no matter what you do.
I personally use the dry packets that you can get a walmart.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 06-19-2014, 05:30 PM   #4
We are using it. Yes I put in extra water when I put in the treatments. It's the kind like you get at walmart that are measured out in the individual bottles. I believe they are made by Camco.
Old 06-19-2014, 05:41 PM   #5
Exhaust fan on with door closed? That would make it ripe!
2015 Rockwood 2608WS
2007 Dodge Ram 2500
Makers Mark is offline   Reply With Quote
Old 06-19-2014, 05:59 PM   #6
Ford Idaho's Avatar
Ok, for in use how much water are you leaving in the bowl?
Little water will help keep the gas down.
Old 06-19-2014, 06:13 PM   #7
We have had the door closed and it did get a little warm inside. We are leaving the door open now and it seems to help. We will also leave a little more water in the bowl.
Old 06-19-2014, 06:24 PM   #8
Ford Idaho's Avatar
Try turning the vent fan off when not in use.
Old 06-19-2014, 06:45 PM   #9
If there is water in the bowl, it should not stink regardless of whether the fan is on or off. I suspect he has one of the messed up toilets that are being replaced.
Old 06-25-2014, 10:01 PM   #10
Boss Ox & Drovergirl
oxcamper's Avatar
What make and model toilet? Could be the seals. Dometic 300's are notorious for bad seals and they modified the unit and will send out a replacement. "gunk" gets stuck up under the toilet base and doesn't get rinsed out. Could be the problem;
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
black, black tank, tank
