Old 09-15-2019, 08:05 AM   #1
Location: North of I-10 & South of I-94, but East of I-5 & West of I-95
Black Tank Smell when Flushing
Hello All.
42' Forest River P-Dek, Fifth Wheel
I get back to my camper about 2 weeks later, and now I have a strong Black Tank smell when I flush the toilet.
This is new as it was not there when I left the camper previously...it happened in a 2 week span while I was away.
I've flushed the Black tank, which helped a little, but it is still there.
Also, when opening the toilet valve (foot pedal Dometic) it once spit up from the Black Tank.
I have not been on top to check the vent pipe. I'll have to do that the next time I'm out here.
Thanks for the help
2nd House is offline   Reply With Quote
Old 09-15-2019, 09:28 AM   #2
SeaDog's Avatar
If the black tank is pressurizing I would get up on the roof and see if the air vent is plugged.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-15-2019, 09:42 AM   #3
cavie's Avatar
When my toilet burps it's the signal to dump the tank.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-16-2019, 07:11 PM   #4
So if the vent is clogged, as I recall, this vent pipe runs down inside the wall, and directly into the Black Tank.
If this is true, then I should simply be able to ram a hose down with the water on to unclog anything that may be in there.
Of course, I'll have the drain valve open so as not to overflow the toilet inside.
Thoughts?
Thanks for the help
Old 09-16-2019, 09:50 PM   #5
SeaDog's Avatar
it may be a nest that you can just take a coat hangar bent with a hook and pull out of the vent pipe I would rather pull something out they flush it into the tank, however that might be the only way to clear it if it is clogged. Like cave mentioned are you sure the tank drained?
Retired Navy
Old 09-17-2019, 08:34 AM   #6
RV There Yet?
IsleDog's Avatar
we had the same issue with our black tank. make sure the bathroom fan is not on, it can draw some nasty smells out of the tank when you flush.
our smell was not caused by a clogged vent, but the vent cap is terrible. we replaced it with a 360 siphon vent and that has completely changed everything! you will also want to make sure your tank is being flushed each time you dump. if its not running clear, you are leaving something stinky in there.
https://www.amazon.com/Lippert-Compo...a-569424062280
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 09-17-2019, 01:58 PM   #7
rlh1957's Avatar
My wife can tell you... Turn off any exhaust fans. The fans will pull the smell out by creating more negative pressure than the sewer vent pipe to the roof. If you only have toilet smell when you flush then some fan is pulling it back on you. Yep that bathroom vent fan needs to be turned off when you flush.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 09-17-2019, 03:49 PM   #8
What additive are you using? For years I used ODERLESS, Switched to Bio-Active. Never had any odor from either one and the Bio-Active does an excellent job in breaking up solids and dissolving paper
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 09-17-2019, 05:33 PM   #9
We use TST treatment from Walmart in our houseboat. Works fine, once we got the vent cleaned. We use the Geo method in our ROO. No smell from either.
mnoland30 is offline   Reply With Quote
Old 09-17-2019, 07:42 PM   #10
If you cannot locate a problem with the black tank it could be a bad AAV valve under the sink. The order can be just as bad.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 09-17-2019, 08:00 PM   #11
rlh1957's Avatar
We use Walex brand... Amazon, Camping World or other RV supplies places. The Bio-Pak are great. Different scents. Drop in tank.
24WS
FX4 Off Road (4X4)
Old 09-18-2019, 12:05 AM   #12
Black tank odors
We use "Happy Campers" brand holding tank deodorant which isn't really a deodorant. Its all natural and works well. Better than those drop in blue bags..
SLU2 is offline   Reply With Quote
Old 09-18-2019, 12:53 AM   #13
IsleDog: Can we use that Vent Cap in any Travel Trailer? We have a 2016 Cherokee Grey Wolf 26' DBH. Thank you.
[FONT="Comic Sans MS"]
Estelle, DH Kent
2016 Cherokee Grey Wolf 26' DBHS
2006 Nissan Titan
Mostly Empty Nesters
Greekhousewife is offline   Reply With Quote
Old 09-18-2019, 01:14 AM   #14
Your toilet smells for one of the four reasond
1-your sewer tank is damaged
2-your toilet is leaking
3-it has not been cleaned thoroughly for some time
-you have created a clog
Allen Arin is offline   Reply With Quote
Old 09-18-2019, 07:54 AM   #15
2X
grouchmore is offline   Reply With Quote
Old 09-22-2019, 04:31 PM   #16
Problem Solved
So I just got back into town from where my camper is at, and I thought I'd report back the problem.
Got on top, and found that the vent cap had cracked / collapsed and was blocking the vent. Probably been partially messed up for a long time when I used to pull it around the country.
I took it off (if you can call it that, the plastic sort of crumbled apart) cleaned everything up, and I have no septic smell anymore. However, I only have a piece of scotchbrite duck taped on to cover the vent pipe...so it will have to wait a couple of weeks before I get out there again. The good news is the camper is under an RV Port, and the smell is gone!
Anyway, the problem is solved.
black, black tank, flush, tank
