Old 01-02-2013, 03:56 PM   #1
Black tank test
I have a new 2013 Solera 24R.
I decided to test the black tank, both for capacity and for leaks.
When I filled it with clean water until it backed up into the toilet, I was surprised that it leaked underneath. Probably either the pipe down to the tank or the connection to the tank.
Admittedly one would not want to fill the tank that full.
However, is it normal to have a leak if water backs up higher than the top of the tank? I would not expect it to leak until it backs up over the top of the bowl.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 01-02-2013, 04:07 PM   #2
If you overfilled the tank there might be an overflow, like a fuel tank on your vehicle, and water might leak out. Others who have had more experience with these issues will have their opinion.
Most PDI's won't fill the black tank until the toilet is full. Since it is new I might take it back and tell them that you filled the black tank and saw some water draining on the ground. Let them check it for leaks. Also even if most won't fill the black tank plum full it still should not leak. I believe that you do have a problem and the dealer should address the issue. Think about it. Having black waste leaking out just because you filled the tank makes no sense. I've read in the past when people would back flush their black tanks and get distracted they would flood their units. Granted the back flush volume of water would be greater than normal but still even if some leaked under it would be not only bad but wrong to have that chance of leaking underneath.
TeJay
TeJay is offline   Reply With Quote
Old 01-02-2013, 05:11 PM   #3
TURBS's Avatar
Your black tank should not leak upon full .
There should be no vent as black tank water is a biohazard.
Take it back to get it fixed if its under warranty.
Does your paper work not tell you your tank size?
Turbs
Old 01-02-2013, 05:22 PM   #4
Turbs
The paper work says 30 gallons. Reality is about 26 gallons, but that is backed up into the toilet bowl, so 24 is probably more realistic.
Purchased new on 12/22, so I have a warranty. I have a 17 page checklist that I am still trying to work my way through. 4 hours at the dealer got me through half of my list. So from my perspective the walk through was incomplete due to running out of time. I should have planned on 1.5 days for the walk through.
Old 01-03-2013, 06:43 AM   #5
Herk7769's Avatar
Tank capacity depends on the levelness of the tank.
If the tank is tilted towards the drain, air will be trapped in the forward part of the tank preventing it from reaching capacity. Make sure the floor above the tank is completely level before checking.
The black tank should never leak unless either the vent or the fill pipe was not sealed properly or there is a crack in the top part of the tank.
In my opinion, this is a "big deal" and you should get it in for repair asap.
HAM CALLSIGN - KC3FFW
Old 01-03-2013, 06:59 AM   #6
When placed in the fridge, my the bubble level that came with the starter kit indicates that 80 percent of the bubble is within the circle. This is quite likely more level than most people achieve. Getting things level when parked on the street at home is easy.
I will test the grey tank today and retest the black tank tomorrow.
This just makes me wonder how many buyers test their tanks either during the walk through or shortly thereafter. I took delivery on 12/22 and still have not had enough time to complete all of my tests and inspections.
Old 01-03-2013, 07:27 AM   #7
Herk7769's Avatar
Depending on the way the tank is installed (and where), the fridge may not be the best place to test for "levelness" of the tank. It is the best place for levelness of the fridge, for sure.
The way the holding tanks are designed, even a few degrees out of level will prevent a complete fill.
This is very clear when you look at my fresh water tank photo.
Name:	Horst Probe Install 019.jpg
ID:	22681   Click image for larger version
ID:	22682   Click image for larger version
ID:	22683   Click image for larger version
Name:	Horst Probe Install 014.jpg
Old 01-03-2013, 08:29 AM   #8
jim44646's Avatar
When I back filled my tank one time I got it to full and it leaked. I found a bad toilet flange seal. I removed toilet and found dry seal and toilet was loose.
What ever is causing the leak is a warrenty issue.
jim44646 is offline   Reply With Quote
Old 01-03-2013, 08:53 AM   #9
Herk7769's Avatar
Excellent point.
Old 01-03-2013, 09:37 AM   #10
VinceU's Avatar
Just to reinforce it is a big deal, remember if water leaked out above or below the floor, vapor will be escaping 24/7. It will eventually invade your living space and that is not attractive, and very difficult to stop.
black tank
