Old 08-12-2014, 08:29 PM   #1
Black tank valve leak by?
I just took my 2015 XLR 24HFS through it's first true shakedown trip (other trips were only a quick overnighter... this one was for the weekend). One major issue I had right off the bat was that when I went to remove my stinky pipe cap, there was roughly 1/4-1/2 gallon of some really nasty water (no visible solids though) that came out. The valve was completely closed during our travel, but the tank did see some use while on our way to our destination.. but I would think the valve would prevent any of that wonderful water from getting into the small section of pipe between the valve and the cap. Is some leaking of that valve normal? If so, is there anything I can get that would help prevent the water from leaking out before I am able to get my slinky hooked up? I really don't want to dump a bunch of nasty water every time I hook up my slinky...
klarowe is offline   Reply With Quote
Old 08-12-2014, 08:52 PM   #2
My black tank valve leaked exactly like you describe for the first few months but the problem went away. My theory is some shavings were caught in the valve during the contruction process but cleared after several uses.
2017 Salem Hemisphere 326RL
2009 Chevy Silveraldo 2500
meandmylabs is offline   Reply With Quote
Old 08-12-2014, 08:59 PM   #3
davel1971's Avatar
I put an additional waste valve at the sewer connection
David & Lynn
Old 08-12-2014, 09:04 PM   #4
I thought about doing this as well.
I will probably give it another shot. I did not actually flush my black tank prior to this past use, so it's possible that something prevented the valve from fully sealing. If it still leaks, then I'll deal with installing an additional valve.
Old 08-12-2014, 09:20 PM   #5
Carknocker Family
Ida Ratherbe Camping's Avatar
Mine also had a shaving caught in it when delivered.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 08-13-2014, 05:32 AM   #6
davel1971's Avatar
luckily mine is just one of the grey tanks that seeps a little, but for only about $20, the extra valve sure reduces chances of making a mess
David & Lynn
Old 08-13-2014, 07:13 AM   #7
Herk7769's Avatar
Me too. It also assists in back flushing the tanks; extending stay times at no hookup racetrack camping by allowing both tanks (and the connecting pipe to be used to capacity; and prevents "wet feet" in the event a valve does not fully close after dumping.
Name:	Twist on Valve.jpg
ID:	60399   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 08-17-2014, 11:24 PM   #8
Having same problem with new Silverback. Something needs to be done.
Silverback Iowan is offline   Reply With Quote
Old 08-18-2014, 12:20 AM   #9
Hutch333id's Avatar
I had/have the same problem with my Cedar Creek. Took the rig back to the dealer and they fixed the black tank leak but I still have leakage from the grey 2 tank which, thankfully, is just the bathroom hand wash sink. At the moment I have a twist on gate valve to save me getting covered. At the end of the season it back to the dealer for this and other snags to be fixed. I did contact Cedar. Creek Customer Services about their lack of workmanship and quality control but so far, no response.
Richard & Diane
2014 Cedar Creek 38FL
With a F350 dually
2014 29nights and 3300km.......so far
Richard & Diane
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 09-13-2014, 10:07 AM   #10
Since I had to repair two of the underbelly plastic panels that fell off and dragged beneath my 2008 Silver Back during my last camping trip, I had the opportunity to address a leaky grey water valve and a hard-to-move black water valve. In replacing both valves, I found ABS cement in the gate of each valve. The grey water valve itself was worn out of it's track. The black water valve was "glued in." In following the instructions for replacing the valves, I noted that the factory did not allow a 24-inch radius between the valve and the handle, thus making the cable bend more sharply than it should have. I'm taking the time now to reroute the cables. Frankly, I'm very disappointed to see the "mess of cables and wires" hidden under the panels.
Your grey and black waste valves should not leak or be hard to open/close. If you can't install secondary valves as the others did, I'd replace the valves.
ID:	62690   Click image for larger version
ID:	62691   Click image for larger version
2008 Silverback 30LSA
2011 F-250 SuperDuty 6.7L Diesel
JRPhotoNut is offline   Reply With Quote
black, black tank, leak, tank
