Old 10-29-2015, 08:21 PM   #21
deebarjay's Avatar
not following you vince...i stuck a long thin bamboo rod straight down the vent pipe from the roof...it bottomed out into the gray tank...no lateral.
.........now you can only see so much of the build and i cant see any connect to the black tank,......the vertical vent pipe isn't anywhere near the black tank....it's a good 3ft away going vertically into the gray....but who knows whats under the shower ....might be a lateral there....i works just the way it is so gonna leave it.
did you read that other black tank thread...people in colorado with the toyhauler....man i feel so sorry for her.
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
Old 10-29-2015, 09:50 PM   #22
Just a member
kandl's Avatar
Originally Posted by deebarjay View Post
....that's why my cap comes off going down the road. factory plan it this way...who knows...but i aint gonna worry bout it any more. which makes me think that people that get nasty smells in the bathroom are plumbed the same way but their flush cap not blowing off like mine.
The cap for the flush connection still shouldn't come off. Not if the check valve is working properly. There should be a check valve in the black tank flush line.
A 35 gal black tank needs to be vented. I would be real worried about it. Something is not right here.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 10-29-2015, 10:17 PM   #23
deebarjay's Avatar
you would think the vertical vent pipe up to the roof would connect directly to the black tank...not the gray tank....i dont know...but i am not going to start ripping things apart....the black tank flush outlet is a good two feet above the tank,so if the valve is not closing, its too high up to let junk escape.... .
10040/31
Old 10-30-2015, 01:49 AM   #24
Just a member
kandl's Avatar
Warranty?
accessories, black, black tank, tank, vent
