Hi all - during our last camping trip I backed up and hit a rock with the black tank dump plumbing. I was lucky and the break was clean enough that with some parachord and duct tape I was able to get things stuck together and dumped the tank when I got home with only a cup or so of leakage into a catch pan.
Now I'm looking at what I need to get to fix it up and I believe I'll need to buy a new "
slip hub flange" I'll replace the valve itself just to be safe but before I get going on this I wanted to ask the experts a couple questions. I also have attached a couple pictures to show what I think is broken (the break is so clean it doesn't look "broke").
At first I thought I could just cut the pipe back a bit and buy the flange I linked above, glue it up and be done. However, it looks like for my TT the grey and black tank are attached to a special Y pipe with the flanges made as an integral part of the Y. Am I seeing that right? Will I have to buy that entire Y fitting? If so, is that a "dealer only" item? Could I use ABS cement to just glue the flange back on the original pipe?
Any suggestions or clarification of what I'm seeing will be appreciated!
